No comments since May 22nd. What's up Vitaliy?
@Vitaliy_Kiselev
Thank you, Vitaly
I've been using the internal mics recently on an interview (there was no wifi there at all), i'll post it as soon as it gets edited.
It could be interesting.
How is the level?
As I don't hear much in the headphones in Mid, and later it is noisy.
But they are extremely (!!) hard to get off, in fact, i think it's impossible!.
I think that you need to glue some small thing (like bump) to them, so you'll have thing to hold, after this it'll be easy.
just up the Mic_vol on the receiver?
Yep.
Is it on both channels then, or one only?
As I remember, on both.
I've also just tested them quickly and found signal drops a lot. But this might be because there is no free wifi channel in my area. I've been using the internal mics recently on an interview (there was no wifi there at all), i'll post it as soon as it gets edited.
Another plus: you can power and charge them with 5v USB. That's very good news for the receiver (if you've got a battery pinch on your rig), as you don't need the internal battery and can keep it as a spare for the transmitter (i've not tested yet if you can load the empty battery in the meantime in the receiver, which would be really nice). But they are extremely (!!) hard to get off, in fact, i think it's impossible!.
Another minus: there is no phantom power on the mic input. So I can't use them with my DPA. I believe the tram and sanken both need a little power as well!? Anyone has a good lavalier mic suggestion for this situation?
@Vitaliy_Kiselev how did you mix the TX and RX internal mic sound? just up the Mic_vol on the receiver? Is it on both channels then, or one only?
Some initial opinion.
Good things.
All below is preliminary due to 5 minute test using one mike (and build in mikes) and two headphones only. I used Panasonic stereo electret mike.
Problems:
So, for now I am not recommending getting it.
Yep, I got it.
But need to find some time to test them out.
Again, no. Our post in delivered on special worms. So it takes forever, especially for dealextreme.
Good day Vitaliy, Have you received the parcel finally? What is your opinion about ROWA wireless system?
It is not DX, it is our post :-)
Is the mic coming from China to Russia on the back of a camel ? Its amazing how much time DX is taking for a country that shares a border with China.
this is about the most useful comparison I've found. There are a ton of mic reviews on YouTube that are people saying "I've gott this mic, its OK" with no comparison.
to my ears the sanken sounds the nicest. Im all ears for cheaper alternatives :)I ordered one too, made a login here just to update with infos as soon I got it. I think it's promissing, but I dont believe it comes with a lav mic, so, any recommendation for me?
@vitaliy_kiselev have you receive it? Please do a review. I am interested. Thanks
Nope. Not yet.
Vitaliy - did you receive it yet?
I've discounted the use of wireless before seeing this - either too expensive or potentially too crap. My limited experience with lav mics dates from 15 years ago, if a half decent mic is $50-100 its still in my price range. If they're more like $300, I may just wait a wee while.
Any mono or stereo mike with proper jack must work.
any suggestions for lavelier mics to go with this?
btw: More details on the Rowa here: http://www.rowa.tw/EN/goods.php?id=877
There are more digital wireless broadcast systems, like ZaxCom, AudioLTD or other $ 2000 + solutions. But these are in the 400-900 MHz range, meant for broadcast wireless systems. As are the Shure PGXD system and the Lectrosonics systems.
Those - 10x more expensive - systems are not in the 2,4 GHz Bluetooth, Wifi (and microwave!) frequency range, like the Rowa and Line 6 systems. This frequency is very crowded and also more directional-sensitive.
I guess sound quality of these Rowa's will be good, and it looks like you can power them with 5V from your rig, and there is a separate headphones out as well as line out (volume adjustable to GH2 input levels?). So at first sight this looks very good for a set that costs less then $ 200.
So it could be a great alternative for those expensive TxRx sets or even the current $500/600 Sennheiser sets. At this price, the real interesting thing is if the wireless reception is good enough for avarage use. Do you know if those Line 6 owners use their system at run&gun location work, or only fixed positions? Both are 2.4 GHz digital diversity systems so I guess they'll hold up the same? It would be interesting, as I am looking for an extra set as well.
If I understand correct the cheaper 400-900 MHz systems like Sennheiser G3, Sony U1 and Audio Technica 1800 are not digital? Did anyone test the (also cheap!) Samson Airline Micro system?
Lectrosonics is the only with with a digital transmission.
Not only Line 6 digital systems are alternatives.
Also Shure has digital systems:
http://www.shure.com/americas/products/wireless-systems/pgxd-systems/index.htm
Its analog over a 2.4GHz spectrum. Lectrosonics is the only with with a digital transmission. They conver the analog signal to digital before sending it out and decode it on the other end,
Can you tell me source of your information?
None of the specifications say this.
Their home page has "complete digital wireless stereo microphone system"
Same on the cases "digital wireless system".
Looking at 86db SNR and 80db stereo separation it also looks like digital specs.
Of course it can be not entirely true, we'll see :-)
It is also wrong. As Line 6 systems exist for years that are very advanched digital systems working in same 2.4GHz range.
I suggest you to try Line 6 systems. As far as I talked to owners they are very good (fully digital). But they don't have any on camera solutions.
I would be curious about the reviews. ALL the cheap wireless mics I tried sucked so far. Transmission is not digital. Its analog over a 2.4GHz spectrum. Lectrosonics is the only with with a digital transmission. They conver the analog signal to digital before sending it out and decode it on the other end,
