GF2 720P PAL ALL I-FRMAE CROSSED 100Mbit
@kirankdwd Forget AQ modes for now, try using IQ=20 and Q= 20 minimum, try and get the i frames to steady themselves, peaking at higher detail.
@kirankdwd: Just looking at the StreamParser screenshot you've attached, it appears the camera is dropping down to a lower quality fallback mode after 16 frames or so, likely because the settings you've used are too demanding for the camera to keep up.
Tested for 20min recording without problem, tomorrow i try some decent test and post screen grabs
thanks for your efforts " Vitaliy_Kiselev "
