Anybody experienced Fujinon (or Canon) 7.5-90mm 1.4 on GH1/2?
I am planing to buy the Pentax C22525KP 25mm F1.4. Its the poor mans NOKTON 25mm... check out this clip:
If you after clinical, sharp images up to the corner and think a lens must not vignette at all this is for sure NOT for you. But if you after some low light shooting for small money you might actually like this lens.
I found it on ebay quite cheap: http://www.ebay.de/itm/Pentax-C22525KP-25mm-F1-4-22-C-Mount-Lens-W-Locking-Screw-/270878274340?pt=Camera_Lenses&hash=item3f119a7324
There is only one drawback: Shipping is about 60$! This is pretty anoying. So I am looking out for two other people in germany who want to buy this lense. Then we can share the shipping costs.
Small calculation
183 € 3x lens
63 € 1x shipping
5 € 2 x DHL (porto für zwei mini päckchen)
251 €
/3
84 € per person (rounded up to euro)
If you are interested send me a private message. Hope this is ok for you Vitaly, actually I am not trying to make money, but only to save some. If you organize a special deal I would for sure prefer this.
On the other hand, once you use ETC all your lenses seem too long because of the ETC multiplication factor. My Pentax 6mm CCTV lens is the only way I get a medium wide lens with ETC (about 35mm equivalent if you take 50mm as "normal"). Bright & sharp, but no longer as cheap.
It should work in ETC, but mos�t likely not without. As written above, 25 mm is pretty much the shortest focal lenght available from CCTV market that does not vignette.
@RRRR Yeah I agree - below 25mm!
That is a tad melodramatic, Roberto! What works for you might not work for the next guy, and the same goes for everyone!
Basically, count out using c-mount lenses below 25mm in anything but ex-tele mode. At around 25mm some vignette more heavily, some don't. I recently got a very cheap fujian 35mm cctv lens which is pretty nice, and a lens I've been using quite a bit (both for stills and video) although I have Canon and Zeiss in the same focal length.
C-mounts usually come with a particular look and are usually not a replacement for cleaner or sharper optics. Most C-mounts look pretty individual and there have been extensive testing on the gh1 and other m43 cams, not so much on the gh2 - just google away to check out individual lenses.
The M4/3 frame is 13.0×17.3 mm. (actual image area, not the whole sensor).
16mm Film has a frame of 10.26 x 7.49 mm
Super-16 Film is 12.52 x 7.41
If you get a C-Mount lens built for a 16mm or super-16mm camera and it doesn't vignette on a GH2, you're lucky. These are basic questions. I'm happy to read people's anecdotes about being lucky with lenses, but I don't want others to be misled into buying lenses which won't work.
Anyone tried this lens?
http://www.eneo-security.com/item/5000058/5000057/0/101608/c0814mvmp.html
