For 'Encoder Setting 4 1080p', the tip says its for 50i/60i. Is this meant to say 24p? (the 'Encoder Setting 2 1080i' starts just below this) The constant on ES4 is 8.
First, your need class 10 card, of course. Next, it is not card problem. You can also try larger Video Buffer and Larger Overall Bitrate (in testers section). But on any detailed scene it won't work.
This is exciting. Am I allowed to admit though, that I'm a bit scared to even try this whole thing? Anyway will watch with interest and take the plunge soon!! Feel free to make chicken noises...
You don't need to use 1080 progressive and 1080i50,00>50,00p at the same time :-) 1080 progressive alone is for 25p/30p encoder (depending on your PAL/NTSC setting). Whole point of this patches is to try them on very low detailed scene, like out of focus dark corner :-)
I tried to record in 1080i (pal version) and return a error about the speed of the card... I had to take off the battery to shut down the camera. Then I plug the nanoflash recorder and still shows 1080i on that device, but then it record to the SD card while pluged to nanoflash... the picture is completed screwed: green blocks and compression artifacts... Didn´t try to record with nanoflash but should be ok, as he detects the 1080i signal!
So do I apply this patch in exactly the same way as what I read about the GH1?
* fully charge original battery * increase version number of hacked firmware by 10 in pTool * copy hacked firmware to the root of the SD card * put SD card in camera * power up * press and hold the slideshow button
Releasing the potential of the gh2, wow I just bought a gh1 and am completely happy with it for documentary work. I´m waiting for the global shutter hand held dream gh camera. thanks :)
hi there. What do I need to download to download and apply the patch? Where can I download it, forgive me but I'm a little confused. How to I change the language from Japanese to English?
