PTool 3.60d topic
  • 259 Replies sorted by
  • Thanks Vitaliy ! I see that there is no warning for the MJPEG adjustments, does it mean that you (partially) successfully tested it ?
  • ciao HenryO sei italiano
  • Congrats man! Looking forward to using it!
  • Wonderful news!!!!!Bravo
  • @gbevin
    Remember point 3 of my second post in this topic, please.
    Also remember that last patch about ExTele in testers section is cruicial (means that it can brick your body).
  • Fantastic news. Bravo!!
  • Congratulations Vitaliy!!!
  • Thanks a lot Vitaly, trying it out now!
  • 1. You'll need this base firmware:
    http://www.personal-view.com/talks/discussion/330/new-gh2-firmware-leak
    2. StreamParser by Chris Brandin as help tool to analyse AVCHD streams -
    https://www.personal-view.com/gh1hack/StreamParser.zip
    Other good idea is also use trial version of Elecard StremEye - http://www.elecard.com/en/download/products.html
    3. Remember that most bitrate and fps patches are for testers.
    Most of them work quite strange, so do not expect current GH1 patches behaviour.
    With time we'll be able to understand GH2 AVCHD encoder better.
    4. How to update firmware:
    a. Load GH2 1.0E firmware, see 1. how to get it.
    b. Check all necessary patches, Version increment must be always checked.
    c. Save firmware. Just change last digit to any number you want.
    d. Copy firmware to root of SD card. Fully charge you battery. Do not even attempt to use AC coupler!
    e. Power off your camera if it was on.
    f. Power on camera. After this press (not hold) green play button.
    g. You'll see hourglass and prompt to update.
    h. Press down arrow and after this Menu/set.
    i. Wait until upgrade will be completed.
    5. How to privide reports in this topic?
    a. Use systematic approach (one-two changes at a time with careful thinking).
    b. Shift-Click on round button in PTool to save your particular settings.
    c. Paste here settings with detailed observation + MediaInfo screenshot + StreamAnalizer screenshot.
    5-999. Reserved.
