Slo Mo in 1080
  • 56 Replies sorted by
  • @mozes: Is the directshow plugin it working 100% for you? As an input plugin I have nothing to complain (aside from having to configure the input do be directshow on the File Open dialog), but sometimes VDub hangs when outputting (it crunches almost all the video but freezes at the last frames). I have no idea but I suspect it might be related to b-frames use (either on input or output). In case you have problems, there is an alternative plugin for Quicktime which I've given a quick test and seems to work also for AVCHD: http://forums.steves-digicams.com/editors-photoshop-vegas-final-cut-pro-kdenlive-etc/172321-importing-mov-1080p-720p-hd-videos-eg-kodak-zi8-directly-virtualdub.html#b
    @mpgxsvcd: How do you rate 720@60p against 1080@60i (properly deinterlaced) in terms of spatial/temporal resolution?
  • Damn it did look good, but indeed, things are speeded-up...
  • Frame rate changes for MJPEG does not work. It has been tested numerous times and now it has been abandoned.
  • i cant find that topic. if it is a post in a topic, a will never find it...
    but if i set it higher then 50fps, then double frames starts to appear.
    will test it against a fast moving object, in real live. ad home dosen't work so great :lol:
  • good luck.. justed looked for it and could not in a hurry. But I remember people has been testing higher framerates and failed.
  • did try it again, 4 sec rec. and 4 sec says sony vegas with a total of 200 frames.
    so this is not a 4 sec recording and packed in a 2 sec file. with 100 frames, If its thrue wat you are saying @meiermans i will check that thread to see what i mis........... if i can find it.....:-o
  • i did shoot 4 sec. and did get a file with 4 sec. and 200 frames. i will check it some further ;-)
  • "it real shoot in 50p i don't see any dubbel frames" Guess this is because the cam keeps recording at lower FPS but writes 50 FPS into file. So things will look speed up. Has all been discussed.
  • I just have the mjpeg set to 1920x1080 and frames to 50 nothing else updated, for so far i can see, it real shoot in 50p i don't see any dubbel frames,
    In sony vegas pro 10 i see that it is a Avg overal datarate 6,653Mbytes/sec.
    Quality is not so good, but i think that can be fixed, sadly enough not by me :-(
  • And light, light light! Fastest lenses preferred.
  • Frame interpolation software such as Twixtor performs best when there is little motion blur. So shoot with the fastest shutter speed you can. Twixtor can add motion blur back after doing the motion tracking.
  • @mpgxsvcd
    exactly!
    When it comes to motion estimation - horizontally moving objects (through the frame) usually causes issues that are though to solve.
  • @tida
    I am using that plugin and it does work well for people. However, the interpolation falls apart for very detailed and fast moving objects just like Twixtor can. Sometimes just a simple slow down is all it takes.
  • @RRRR
    That is great advice. So for the 1080p @ 30 FPS mode if you wanted to interpolate it to 40% then you would need to use 1/150 or 1/160(closest on GH2), right?
    Another thing to remember is that if you want to do indoor slow motion the highest shutter speed you can use is often 1/120. That means that 30 FPS is the highest frame rate you can actually slow down.
    I shoot a lot of very dynamic indoor rock climbing videos in poor light and so I love the new 1080p @ 30 FPS mode with version 1.1 firmware. I can shoot in 1080p @ 30 FPS the entire time and set the shutter speed to 1/30 for the really dark areas with static moves and then crank it up to 1/120 when I see that they are going to do a dynamic move.
    I will be shooting a lot of video at our Divisional comp this weekend. These kids are some of the best climbers in the country competing for a spot at Nationals. There should be some really good dynamic slow motion footage from this comp.
  • I think if you want to deal with motion estimation for free you should look at avisynth plugin MVTools. Many people claim that quality is comparable to Twixtor.
    It would also be possible to start and end the slowmo gradually like it was discussed here: http://forum.doom9.org/showthread.php?t=161835
    You can save this script as avis plugin for avisynth in its plugin folder. And as @RRRR metioned you should calculate the final shutter speed for your shot before.
  • @duartix thx for the Directshow-Driver-Plugin link...
  • One of the advice I've seen on here, if you plan to use any motion estimation software - such as Twixtor - applied to 720p50/60 or 1080p30 (80% mode) is to estimate the frame rate which you wish to have in the end and when you shoot your scene you should apply 360 degree rule to the approximate outcome frame rate.
    In other words, if you shoot 60 fps which you plan to try and expand to 120 fps in post with Twixtor - use a shutter speed of 1/240 (rounded up to 1/250 on the available shutter options)
  • The 1080p @ 80% is still the best the GH2 can do at 1080p. It records true 1080p @ 30 FPS and slows the playback down to 80% to give you a slow motion 1080p @ 24 FPS file. It just isn’t that slow.
    Try shooting 720p @ 60 FPS and 1080p @ 30 FPS 80% Slow motion. Slow the 720p down to 80% or even 40% and compare them. If you have a tight enough shot I don’t believe you will really be missing much detail with the 720p. Being able to go down to 40% instead of only 80% is much better though.
  • If you are rendering in VirtualDub, there is no need to use vegas, you can open MTS files directly with this: http://forum.videohelp.com/threads/286901-VirtualDub-Now-Has-a-Directshow-Driver-Plugin I've opened 1080i50/60 and deinterlaced properly to 50/60fps. Here's the config.
    662 x 299 - 29K
  • in vegas render as uncompressed avi. change nothing in vegas! load in virtualdub, and render to whatever format you want in 50 or 60p. you will be surprised. i don't have a example wright now, but i am sure there are some on youtube. if i am not wrong, i did read that tip somewhere on a virtualdub forum
  • Sry for the late question. I know there are monumental steps already using some of the more recent patches with the GH2. Both with 720p detail and 50i/60i motion. But "JES Deinterlacer" i'e heard tons about being a VERY solid tool to use for converting 50/60i to 50/60p. Can anyone else shed a little light to using this as an effective tool, say over... Avidemux, Fieldskit , or even going through Sony Vegas...?
  • Alcomposer is right, 60/50i converted to 60/50p results in very smooth slow motion when slowed down. Sony Vegas does this very well. You lose a little resolution when you throw away one of the fields, but it's mostly not noticeable as the slow mo is slightly blurrier anyway. I've used this following workflow for years.
    Follow the Vegas sample in this link http://eugenia.queru.com/2009/02/09/butter-smooth-slow-motion/
  • For kind of project I will be working with, a good 720p 60p will be just perfect. No need for expensive software.
  • Try this Avidemux de-interlace method => Bob, Temporal & Spatial Check
    http://www.avidemux.org/admWiki/doku.php?id=using:video_filter_yadif
  • @Paerone
    Can you share the footage that you have found the '24 in 60i/50i' to be true? I have used 50i/60i for slow-motion and I have not found this to be true.
    Converting the 50/60i footage to 50/60p yields unique frames. (I have filmed a falling object and it is very clear then).
    Cheers,
    A
