Basic PTools problem, noob
  • I need some friendly advice:
    Using mac with winebottler.
    Able to launch PTools and possibly load GH__V10. Then nothing more.
    In PTools, don't see any patches that also reside in the same folder.
    In PTools, nothing responds other than highlighting the top three choices and the Save Firmware button.
    Screenshot of PTools and Folder is attached.
    Anything probable or usual about this?
    If it might be a PTools problem, maybe remove all trace of PTools and WineBottler, then redo setting that up?
    Thanks mucho.
  • 3 Replies sorted by
  • If you can start PTools, Wine is running OK.
    Probably you did not load the original firmware.
  • Make sure to double click the User Patches list item
  • Use Beginners and basic questions topic for this, ok?
    And try to read FAQ (link on top)
