First leaks about Intel impotency
Screenshot of some dvelopers doc page, so it is LGA 1700 for certain.
                  Alder Lake-P (notebook chips)
Alder Lake-S (desktop chips, can be used in gamers notes)
Geekbench
                  On mobile ones
                  Very big power consumption
The Chinese portal FCPOWERUP, shared interesting information, taken, apparently, from Intel documentation for power supply manufacturers. It describes the power supply requirements for systems based on the new 12th Gen Intel Core processors, and specifies the constant and peak power values that the PSU must supply over a 12-volt power line for stable operation of Alder Lake chips with different TDP levels.
The documentation lists the requirements for processors with TDPs of 165, 125, 65 and 35 W. At the moment, there is no confirmation that Intel is going to use a hybrid architecture in HEDT processors, so chips with a TDP of 165W may not appear on the market at all. It is more important to pay attention to the requirements for processors with different power consumption indicators.
While the current requirements under continuous loads for 12th Gen Intel Core chips generally remained at the same level as for the current 10th and 11th Gen Core models for the LGA 1200 platform, the requirements for peak current values have increased markedly ... For Alder Lake models with a TDP of 125 W, the PSU should supply a maximum current of 39 A (468 W) on the 12-volt line in short-term mode, and not as before 34 A (408 W). For models with a TDP, this value increased from 30 A (360 W) to 38.5 A (462 W). And even the energy efficient 35W TDP models require the PSU to be able to deliver 20.5A (246W) peak loads. Thus, for 125-watt Alder Lake models, the required power supply of the PSU increased by 15%, and for models with a TDP of 65 and 35 W - by 28 and 24%, respectively.
This means that problems with the use of Alder Lake-S chips in theory can arise in systems that use old PSUs with multiple power lines (Multi-Rail). In these, the current on each individual line is typically limited to 20 A.
                  PurgetBench for After Effects
                  Sources confirm that Intel's 12th Gen Core processor lineup, along with Z690 motherboards, will be available on November 19.
Some benchmarks
                  A sample of the upcoming flagship 16-core Intel Core i9-12900K processor of the Alder Lake generation turned out to be noticeably more productive than the 16-core AMD Ryzen 9 5950X flagship processor in the multi-threaded test of the Cinebench R23 benchmark.
Despite the difference in the number of threads, the Intel processor was able to outperform the AMD solution. The Core i9-12900K scores 30,549 points, while the Ryzen 9 5950X scores 25,586 points in this test. The current flagship Intel Core i9-11900K scores 15,325 points in the same test.
Core i9-12900K price will be $699
This chip will have a 3.2GHz operating frequency, capable of 5.2GHz in Turbo Mode, with 16 cores and 30MB of L3 cache. As expected, the specs reveal it also supports DDR5 memory, PCIe Gen 5, and the Intel Z690 chipset motherboards that should go on sale at the same time.
