"After making these mods, would the R5 record 8K video for longer than 20 minutes? No. Even though the camera was staying much cooler than it did before it was modified, it still shut down after 20 minutes of recording due to a timer-based heat management solution baked into the camera's firmware."
Lol
shame on you canon!!!
DXO sensor mark
Canon EOS R5 sensor represents a high watermark for Canon. The maximum dynamic range is competitive with the best in class, and the R5 sensor offers a useful advantage at some crucial ISO settings over its rivals. It also has excellent color and low noise at high ISOs, which all go toward making the Canon EOS R5 one of the most well-rounded performers in this important category. It may have taken a while to get here, but the Canon EOS R5 looks set to be the one to beat.
https://www.dxomark.com/canon-eos-r5-sensor-review-a-high-water-mark/
Fixed it for you: Canon EOS R5 looks set to be the one to heat.
"The one in heat?"
In stock at Adorama
Setting up
EOS R5 -- Firmware Version 1.3.0
- Added Canon Log 3 to Canon Log settings, a log gamma curve that possesses largely the same characteristics with Canon Log 1 but with a wider dynamic range. It is also found in our professional line of cameras, the Cinema EOS Series, allowing easier post-production camera matching work between the EOS R5 with Cinema EOS cameras.
 - Added Low Bitrate recording option, allowing users to shoot smaller file size footage with lower image details. This is very useful for longer recordings that do not require the best possible image quality or when storage space is a concern.
 - Added 120p Full HD video recording, allowing users to have the flexibility to select the desired resolution for slow-motion content thus allowing more convenience during post-processing.
 - Electronic Full-time Manual Focus
 - LCD Backlight OFF option
 - FTP Transfer Status Display
 - Protect Image Transfer
 - Save/Load Settings on Card
 - Fixes a phenomenon, in rare cases where the camera does not function normally when using certain CFexpress cards.
 - Fixes a phenomenon, in rare cases where the camera does not function normally when the drive mode is set to "High-speed continuous shooting" to shoot still images continuously.
