3D 3K 12-bit RAW camera project
  • 133 Replies sorted by
  • I haven't played with it in 3 years. But the binary worked then. Maybe compile the source again
  • I just tried with the included SDK installer and all is working now. Thanks!
    I've now got a crash when saving DNG's using the sync FlyCap, but that is probably something to do with my system (USB/memory related). I'll figure it out.
    Thanks, Dustin
  • Hello zcream, I tried your version of Flycap with my Pointgrey Blackfly usb3. It is recognized. Jpg recording is fine, but DNG is not working well. Here is a screenshot of a dng I get. Is there anything I can do to make it work? Or does your software only works with Flea3, not Blackfly? Thanks
    570 x 443 - 697K
  • Here are better examples : one is screenshot from jpg in flycap, other is screenshot from dng in flycap Thanks
    576 x 434 - 710K
    570 x 440 - 390K
  • I had to modify the dng from flea3 as its got endian or format issues. Since yours is a different camera, my code is not picking it up.
    In the same public folder, you will find Flea 3 project zip file. That has the code. You can download it and try to modify it if you wish.
  • Ok thanks. I downloaded your project file. Which files should I modify? I'm not a programmer, but I could ask somebody to do it. Thanks
  • Look at the dates. Only some files are modified. Also, it may be as simple as looking at the dng code, and searching for a place where I check the string "Flea3" Remove that check that the code will run for all cameras.
  • Ok thank you
