Apple: Another rendering M1 test shows that Cinebench is rigged
  • Cinebench where more than 50 Apple engineers helping with optimizations
    Real not specially M1 optimized benchmark with similar calcs
    ChameleonRT https://www.willusher.io/graphics/2020/12/20/rt-dive-m1
  • 6 Replies sorted by
  • @radikalfilm
    I posted info from another topic, it is from reversers.
    Apple libraries silently use this coprocessor, but it is not documented and mentioned anywhere, official APi is absent.
  • @Vitaliy_Kiselev Secret coprocessors? SECRET coprocessors? Did you mean private API? If they were secret you wouldn't know about them would you.
  • The M1 architecture is all about coprocessors though, if most of the die is sitting idle and you're only using the ARM cores, the software isn't optimised enough. Good software engineers will use the hardware available on the chip.
    Yes the marketing is misleading though and should make clear what the GPU utilisation is when talking pure CPU benchmark figures.
    As for user perspective, I care most about how well my specific software runs for certain tasks - and synthetic benchmarks are rarely a good indicator of that anyway, either on Intel or Apple.
  • Why is avx2 faster than avx512?
  • @AndrewReid_EOSHD
    Haven't Intel and NVidia been playing the same tricks for years?
    No, not same. And they did not have such wide, extremely coordinated and tightly controlled PR things.
    Last Nvidia PR releases are similar, but much smaller in scale and not controlled after around 7 days.
    Apple controls everything (for top influences) for months.
    In real software I am all for optimisations if it improves genuine performance... With all new architectures there's the most room for new optimisation.
    One of issues here is that Apple PR tell about ARM cores performance while up to 40% of performance are actually using GPU parts and public or secret coprocessors.
  • Haven't Intel and NVidia been playing the same tricks for years?
    But you are right to call out devious marketing when you see it.
