70-200mm F4 Canon RF Lens
  • Specs
    • f/4 constant maximum aperture
    • Dual Nano USM focusing motor
    • L-series quality
    • UD elements and ASC coatings
    • 5-stop Optical Image Stabilizer and 7.5-stop combination IS when used with the EOS R5
    • Dust and water-resistant seals
    • Lens Control Ring
    • £1699.99 / €1969.99.
  • 7 Replies sorted by
  • Firmware Version 1.1.0
    1. Adds an electronic full-time manual focus function (a function that enables constant manual focus adjustment in both One-shot AF and Servo AF), which is enabled when using the EOS R5, EOS R6, and EOS R3 cameras.
    2. Improves an issue in which the background is not blurred when performing slow panning with the IS (Image Stabilization) mode set to Mode 2 or Mode 3.
    Download firmware v1.1.0
  • December 17, 2020
    Regarding the “RF70-200mm F4 L IS USM” announced on November 4, 2020 and scheduled to be released in late December, due to production reasons, we cannot prepare a sufficient supply amount for the release. Therefore, we have decided to postpone the release in early March 2021.
    We would like to inform you and deeply apologize.
    Scheduled release date
    • (Before change) Scheduled to be released in late December 2020
    • (After change) Scheduled to be released in early March 2021
    We apologize for the inconvenience caused to the customers who are waiting for us, but we will do our utmost to launch it, and we appreciate your continued patronage.
  • PR
    Canon U.S.A. Inc., a leader in digital imaging solutions, is excited to introduce the compact and lightweight RF70-200mm F4 L IS USM and the RF50mm F1.8 STM, two completely re-designed RF mount lenses with bloodlines to immensely popular EF models that feature new lens formulas and enhanced elements.
    The Canon RF70-200mm F4 L IS USM lens is ideal for photography enthusiasts ranging from advanced amateur to professional skill levels. The compact and lightweight nature of the lens makes it Canon's shortest and lightest 70-200mm F4 zoom lens to date. This RF lens is approximately 32 percent shorter and 11 percent lighter than its EF counterpart with a large portion of the lens element arrangement closer to the camera body. This arrangement is designed to provide photographers with a more balanced feel and experience even at the zoom range's telephoto end. Additionally, the shorter and lighter design allows the lens to more easily be stowed away in a camera bag when not in use.
    The RF70-200mm F4 L IS USM features two independent Nano USM motors, providing an even greater level of high-speed autofocus for still image shooting as well as quiet and smooth autofocus for video shooting. The lens also incorporates a floating focus control that drives the two lens groups individually while using the two aforementioned Nano USM motors. The floating focus lens element shortens the focusing distance and helps reduce breathing, providing users with fast, consistent and reliable performance.
    Additional Features of The Canon RF70-200mm F4 L IS USM Lens Include:
    • 16 lens elements in 11 groups, including four UD lenses, that help to reduce chromatic aberration
    • Optical Image Stabilizer with up to 5 Stops[i] of Shake Correction
    • Up to 7.5 stops[ii] of Shake Correction with coordinated control of Optical Image Stabilizer and In-Body Image Stabilizer
    • Three stabilizer modes
    • Customizable control ring that allows photographers to adjust exposure compensation, shutter speed, aperture, or ISO
    • 12-pin communication system
    • L-Series dust and weather-resistant build with a fluorine coating
    • Minimum focusing distance of 1.97 feet and a maximum magnification of 0.28x
    • Air Sphere Coating (ASC) that helps minimize lens flare and ghosting
