CUDA Performance
Issue with high memory temps
In reality 3080 and 3090 require proper water cooling systems with at least 360mm radiators, but we still have all sites claiming how it is nice and ok.
Main issue is super thermally dense boards due to decision to shorten PCB
NVIDIA PG133 Founders Edition board:
Long term problems are very probable.
Small talk from Taiwan
Engineers who worked on RX3080 and RX3090 design told on local closed group chat that thermal design for cards that have FE boards and even less dense custom ones are indeed horrible. And despite that thanks to special throttling and local power management of the main chip they are able to keep its temperature more or less ok - on the board itself it can be areas of too high temperature, especially near VRM and RAM same as in referenced thermal images above.
BGA and memory issues are very probable.
Next thing - Nvidia actually plan shift main focus and promotion on cards with 16GB and more memory. Including 20Gb RX3080 and 24GB RX 3090. All cards with RAM below 16GB will be called "low end and obsolete models" already in 2021. RX3xxx update will focus to bring all memory sizes to 16GB except 1050/1650 level cards. GT1030 replacement also coming with around 3x performance.
Micro cracking on BGA will be a short term issue with this kind of temperature behavior.
ASUS RTX 3080 ROG STRIX Board - huge waste of resources
RX 3090 board
Very big thermal density, issue with memory cooling is worse than in RX 3080 already bad case.
Rear memory cooling is terrible.
Rumor is that next update will have consumption in the 450-600W range and will have water cooling installed, no more air cooling.
RTX 3080 crashes seems to be hardware related
EK Water Blocks made stuff for RTX 3080 and RTX 3090
Common idea to use transparent acrylic parts is stupid die too big difference in temperature expansion between copper part and this transparent cover. Add to this single sealing - and this thing will certainly leak with time.
On capacitors
RTX 3070 performance
