Mini-review of Minolta SR/MC/MD to Sony Alpha/NEX E-mount adapters:
Big_is (weakpotoman) tripod adapter: very strong springs, good build. Flange focal distance is a little too short, but no worse than any of the others. Easily shimmed internally. Recommended! http://stores.ebay.com/weakpotoman/_i.html?_nkw=minolta+nex+tripod+adapter
Metabones: moderately strong springs, really good build and super strong tripod mount. Flange focal distance is too long! Can't achieve infinity focus on any of my Minolta lenses. Flange focal distance can be reduced fairly easily by sanding down the inside of the camera mount. Not recommended unless you're keen on sanding.
Novoflex: really expensive, no baffles, tripod mount not included, and not the correct flange focal distance (too short by a fair bit). Really strong springs. Don't buy.
Fotodiox Pro: very good build, no baffles. Not the correct flange focal distance (too short by a fair bit). Coarse internal black matte paint seems like it could flake off and get in your camera. Not recommended.
I tried several other eBay adapters and they were all worse than the Big_is adapter.
I didn't try the Rayqual adapter. It has internal baffles. Rayqual has a reputation for extremely high quality and precision. It's available with a tripod mount if you ask the seller.
@hellrazor Yes, I bought that same adaptor (with the tripod mount) and am not happy with it at all. There is play between the body and adaptor, and between the lens and adaptor. So far I've not had any luck with the Big_is adaptors. The second C to M43 I bought from them was just as bad as the first one -- it's a super tight fit on the mount and makes grating sounds when I try to remove it.
Has anyone tried the Kipon MD MC to M43 adaptor here?
I will be getting some nice Rokkor lenses (including a 58mm f/1.2 -- can't wait to try it!) so I'll need to either fix the play issues or get a better adaptor.
@tonalt The video above isn't online anymore -- do you by any chance know of another one?
Yes, and we have special topic for this :-)
I have this adapter, and it's been great: no play at all. It looks almost identical to the one Vitaliy suggested.
I bought that particular adapter minus the tripod section. It holds the lens secure and squared to the camera, but the flange distance isn't quite right. The lens now focuses beyond infinity. Not a big deal - you just have to be careful when you're focusing at infinity. The tripod adapter is only necessary for a really heavy lens. You may not even need it. For example, I use a Canon FD 135mm f2 lens without a tripod adapter, and have no issues whatsoever. This lens weighs 1.5 lbs.
Did anybody try this Adapter with tripod mount integrated? http://www.ebay.com/itm/Minolta-MD-MC-Lens-to-Micro-4-3-M4-3-M43-adapter-with-Tripod-for-EPL1-EP2-G1-GH1-/110773243613?pt=UK_Photography_CameraLenses_Lens_caps_hoods_adaptors_ET&hash=item19ca998edd#ht_4505wt_1019
