CineEye 2 Pro is Accsoon’s new professional wireless transmission system. With innovative 2.4GHz+5.8GHz Dual-Band Transmission technology, it can intelligently identify interference during transmission, then combine the data from these two streams to form the complete audio and video signal, greatly improving its stability and anti-interference capability. CineEye 2 Pro is far more stable than traditional Wi-Fi video transmitters that only stream in 5.8GHz, and once on set, it will provide you with a stable and glitch-free stream.
CineEye 2 Pro further optimized the transmission process, this time taking advantage of both H.265’s high efficiency and higher bitrate. From the transmitter to the receiver, CineEye 2 Pro has less than 0.06s of latency. It also supports 44KHz 16bit synced audio transmission, you can now stream the video with sound. The transmitter can send to up to 4 devices at the same time, and there’s no limit to the combinations of receivers, no matter if its four dedicated receivers, iphones, ipads and android devices or even freely mix and match, you can get synced video stream on all of them. Accsoon Go app supports both Android and iOS platforms. The latency on iOS devices can still reach less than 0.06s. Now you can get sharp image quality similar to online video platforms’ high quality 1080p playback.
- With High Image Quality, Robust Connection, Smooth Playback, Now you can turn you mobile devices into true wireless productivity.
- All aviation grade CNC Aluminum Enclosure, high performance Low power draw chip, 1.3 inch OLED status screen, and fan-less design ensuring zero noise.
- NP-F and DC Input can be hot swapped for long shoots.
KEY FEATURES
2.4GHZ、5GHZ DUAL-BAND TRANSMISSION, MORE RESISTANT TO INTERFERENCE AND WAY MORE STABLE
CineEye 2 Pro is equipped with Accsoon’s Gemini Dual-Band Transmission Technology, allowing It to stream the video signal via 2.4GHz and 5.8GHz Wi-Fi at the same time. Then the receiver can intelligently identify interference and combine the two streams to form the complete audio and video stream, greatly improving its stability and anti-interference capability.
With Dual-Band Transmission, CineEye 2 Pro is far more stable than traditional Wi-Fi video transmitters that only stream in 5GHz. Once on set, CineEye 2 Pro will provide you with a stable and glitch-free stream, handling even the toughest environment with ease.
LOW LATENCY, TRUE WIRELESS PRODUCTIVITY ON SET
Latency is a big thing for wireless video transmitters. From the transmitter to the receiver, CineEye 2 Pro has less than 0.06s of latency, which is the best performance in its range. No matter if it’s monitoring or follow focus, CineEye 2 Pro can handle it.
MONITORING ON THE “BIG SCREEN”, EXPERIENCE LIKE NEVER BEFORE
With Accsoon GO App, the latency on iPad is still less than 0.06s, equal to other professional monitors. Now with more professional monitoring tools in our app, your iPad can turn into a pro-level on-set monitor, but with a 12.9 inch big screen and a lightweight enclosure that’s easy to carry around, giving you a refreshing taste of what smart monitoring should feel like.
1200FT OR 350M OF TRANSMISSION RANGE
Thanks to Dual-Band Transmission, CineEye 2 Pro’s transmission range can now reach 350m line-of-sight. With this long range, you can check what’s happening real-time on set even if you’re quite far away from it.
ONE TRANSMITTER FOR MULTIPLE RECEIVERS
CineEye 2 Pro can send to up to 4 devices. Receivers, iPhones, iPads, android devices, mix and match. Do it however you want.
THIS TIME, WITH SOUND,HIGH QUALITY SYNCED AUDIO AND VIDEO TRANSMISSION
CineEye 2 Pro supports multiple video input of up to 1080p 60fps. Using the new efficient HEVC compression, at the same bitrate, it can give you much sharper image, fulfilling the needs of professional monitoring.
Also supports 44.1KHz/48KHz 16bit/24bit audio input, and it streams the audio with low compression codec, giving you near lossless audio monitoring experience.
PROFESSIONAL MONITORING APP
The best Monitoring App in its class. Supports both Android and iOS. Comes with all the popular monitoring features like: Audio & Video Recording, False Color, Focus Assist, Histogram, Waveform, Loading 3D LUTs and CDLs, Custom Anamorphic Ratio, Custom Ratio Guides etc.
SUPPORTS HDMI LOOP OUT
The transmitter supports HDMI loop out. You use connect it to other devices like monitors, recorders and livestream equipment. Giving you maximum freedom.
AUTOMATIC CHANNEL SELECTION
CineEye 2 Pro supports 20 channels. During its boot time, CineEye 2 Pro will automatically select the cleanest channel to stream, paired with Dual-Band Transmission, it will further improve CineEye’s anti-interference capability, ensuring ultra-stable wireless connection.
ROTATE THE KNOB, AND THAT’S IT!
With CineEye 2 Pro, we abandoned the over-complicated transmitter-to-receiver pairing process, and instead innovatively introduced the “Pairing Knob”. All you need to do, is to rotate the knob on both the transmitter and receiver to the same number, then that’s it. Your transmitter and receiver(s) are now successfully paired!
LOW POWER CONSUMPTION, NO-FAN DESIGN
CineEye 2 Pro has very low power draw, a single NP-F970 battery can last you 20 hours.
CineEye 2 Pro also has no fans inside, ensuring zero fan noise, adding no trouble to your sound recording workflow.1.3 INCH OLED SCREEN
CineEye 2 Pro is equipped with a high-bright OLED screen. Paired with a clean and simple UI, you can easily learn about the real-time connection status and battery voltage. And with simple control logic, you can quickly adjust settings on the transmitter and receivers such as Video Quality Modes and Channel Selection.
**EASY FIRMWARE UPDATES
CineEye 2 Pro support firmware updates. No sophisticated process needed, you can directly update your transmitter and receiver on the app.
CAMERA CONTROL
When using our app for monitoring, you can send Rec./Stop commands to your camera. Supports mainstream cameras like Sony A7/A9 series, Canon EOS-R/5D-MK4, Panasonic GH5/CH5S/S1H, Nikon Z6/Z7, Fuji X-T3 and more. (camera control needs correct control cable for your specific camera, sold separately. Later we’ll release control cable for various cinema cameras.)
LIVE LONG AND HOT SWAP You can power CineEye 2 Pro with NP-F550/750/970 batteries and DC input (7.4V-16.8V), and a single NP-F970 can last you 20 hours. These two power inputs will be automatically hot-swapped, never putting a stop to your work on set.
