(REMOVED) - my mistake, it's all ok with ZRAW
CDNG raw
Higher frame rates on e2c
Guys, what features do you want to see in E2? It's a Linux machine, I can do anything you want.
Here will be posted all technical info during E2 research process:
https://github.com/storyboardcreativity/Z-Camera-E2-Reverse-Engineering
I've found a way to force flash our own firmware without checking it with public key.
@storyboardcreativity Interesting, after checking the concerned sony sensors, some nice options could be added. Maybe some anamorphic 4:3 modes and more color depth. I tried a mavo LF some times ago and i'm pretty sure it uses the same sony sensor as the F6, Kinefinity imho made the best use of it. Good luck ! @Vitaliy_Kiselev About the kick; Sometimes you are too naive...
And one very important thing. I don't know how to publish all these instruments because if they find out how I change firmware, in new versions they will patch these things - it will make research process much more difficult.
Sure, but it will be a bit more difficult because of some things:
It can be two step process - replacing public key in firmware as universal small patch (via remote control or such).
And next just using our own private key as now check will go through.
I've just got full control of camera from my computer, but only for old versions (0.87 and older). I'll need some time to understand how to do it for new versions, they use AES CFB encryption process for their firmwares and checking firmware correctivity with public keys using signatures (of course, I don't have Z-CAM private key LOL).
So, we can't make our new firmwares, but after special operations we can - it's like "JailBreak" for Z-Cam E2.
I still need to find 0.82, 0.84 and 0.86 versions...
Well, you can make small utility to mangle with version number to allow it, but they can have some reason.
WARNING! Don't upgrade E2 firmware to 0.95! You won't have ability to flash back old version after that.
Well, not only everyone but few can speak english such way
Thank you, but my english is not very good for doing something like this :)
If I start my works on this direction, I'll begin with russian-languaged videos.
Does anybody have "update.zip" files with version 0.84 and 0.86 for E2? Links for these firmware versions are present in Z-CAM Facebook page, but links are disabled (locked) - so, I can't download.
These old firmware versions could be very helpful for research.
Can make some nice summaries on PV channel if you like.
It's sad :c
I'm thinking of making a channel where I would talk about hacks. But I think this theme won't be popular - that stops me.
They are nice, but too emotional, kicked me out of their group for HiSilicon and hack posts (despite that PV and me promoted them as hell, did lot of interviews).
If you want to be public figure - you need to learn to talk to press (case it is not another ass lickers as they used to do).
Z-CAM is a great company, I'm really fond of their cameras. Hope someday I'll do something similar...
Hello. can I order a full double staked sensor with dual iso No extra noise. I would like to enlarge the sensor please, with chips make it double SoC.
don’t put on h265 on it since I’m allergic.
To take please.
Ohh I almost forgot. Please enlarge the well capacity too.
Thanks
Interesting how it'll all unwind, as Z-CAM can only keep producing cameras if HiSilicon made stockpile of chips and I am not sure, as they clearly moved all focus to stock mobile LSI.
Checked some firmwares: E2C and E2-F8 have HiSilicon on board too. But for now I'm not sure about chip version (maybe not Hi3559A V100).
Thank you. I'll prepare script to get camera info.
Yes, we can try to do it offline and then owners can send me collected data. It will be saved on camera's connected storage.
