Main features
Tamron announces the development of a new high-speed telephoto zoom lens for Sony E-mount full-frame mirrorless cameras, the 70-180mm F/2.8 Di III VXD (Model A056). Availability of this new zoom is planned for Spring 2020. The lens will be on display at the upcoming Photo Plus Expo in New York City this week and Salon de la Photo in Paris next month.
Developed under the concept of “making high-speed zoom lenses user-friendly,” Model A056 features a compact and lightweight design, an ideal match for full-frame mirrorless interchangeable lens cameras. The 67mm filter diameter is the same as all other Tamron lenses in this series. The optical design includes several specialized glass elements that contribute to the lens’s superb imaging performance and its very short 33.5 in MOD (Minimum Object Distance) expands overall versatility. The lens adopts Tamron’s newly developed VXD (Voice-coil eXtreme-torque Drive) linear motor focus mechanism that produces a quiet, quick autofocus drive.
Other features that support a great shooting experience include a Moisture-Resistant Construction helpful for outdoor shooting and Fluorine Coating for easy maintenance. In addition, Model A056 is fully compatible with various camera-specific features including Fast Hybrid AF and Eye AF. This new model joins the 17-28mm F/2.8 Di III RXD (Model A046) and the 28-75mm F/2.8 Di III RXD (Model A036) and brings Tamron’s total of F/2.8 zoom lenses for full-frame mirrorless cameras to three.
First discount started
Test
70mm
180mm
https://www.lesnumeriques.com/zooms/tamron-70-180mm-f-2-8-di-iii-vxd-p54491/test.html
New firmware
Improvements
- A malfunction of Inner body image stabilizer occurs when used at about 70-85mm focal length and at more than 5.5m of object distance. Applicable camera models: α7 II
- When you use flashes, there is a delay from the time the shutter button is pressed to the time the shutter and the flash release. Applicable camera models:α7, α7 II, α7R, α7R II, α7S, α7S II, α5000, α5100, α6000, α6300, α6500, NEX-3N, NEX-5R, NEX-5T, NEX-7, NEX-F3, NEX-6
