Most fun is that almost all samples used to push this scaler are so bad...
New release
Our Latest Update Improves Stability and Hardware Support
We’ve improved speed and stability so you can process longer videos with better performance.
Check out the latest features and software updates:
- Upscale up to 600%
 - GPU processing on Mac and Windows (New!)
 - Improved speed (New!)
 - Increased hardware support (New!)
 - New AI Models with improved motion stability (New!)
 - Custom processing refinements (New!)
 - DeNoise/Deblock processing
 - Custom output settings
 - Keyboard shortcuts, zoom, and panning (New!)
Anything similar for Windows?
The software has 3 quality levels to choose, and there is a trial version to downloas and test doing some previews. Also the preview can be set to 200% size to perceive the results better.
There is a cheap alternative called GPUResize. It deliver good results using Kaiser+Stairstep method.
Mixed results as per their forum: https://community.topazlabs.com/c/topaz-products/l/latest
Is it just me that I'm a bit disappointed with the results? :(
This is sponsored by C.S.I.
Strips out the audio?
Looks like Topaz Video Enchance 8K, Gigapixel AI for Video will be available for OSX 10.12 & above =)
Most common set :-)
as I see it works only on Windows with NVIDIA GPU card :(
$100 discount still available
If anyone want to make review of it for PV, PM me.
Looks good for upscaling SD video. Probably more useful than trying to get extra punch-in on 4K files.
Looks like it would do well on surveillance video. There are times when you want to zoom into the frame to see the criminal closer up and the video just turns to mush - this should do the trick.
Would also be good if they made a 4x AI zoom plugin for Resolve. So you shoot 4k on you 24-70 and it turns it in to a 24-280 - instant 11.7x zoom lens. Sony seems to do something like this in camera on my A6300, but this looks like it does a better job.
Product Lauched
