PR
FUJIFILM North America Corporation today announced the new FUJINON XF 8-16mm F2.8 R LM WR Lens, an ultra-wide angle zoom lens with a constant maximum aperture of F2.8 and focal length equivalent to 12-24mm (35mm format). Capable of providing outstanding edge to edge image-resolving performance, this lens is perfect for landscape and architecture photography such as interior and nightscape, and astrophotography.
FUJINON XF8-16mmF2.8 R LM WR Ultra-Wide Angle Lens
The new XF 8-16mm F2.8 R LM WR features an optical construction of 20 elements in 13 groups, including 4 aspherical lens elements to control distortion and spherical aberration, and 6 ED lens elements including 3 super ED elements to control lateral chromatic aberration, a lens design that produces advanced image-resolving performances across the entire zoom range. Featuring a floating lens element that adjusts according to the position of the zoom, the XF 8-16mm F2.8 R LM WR achieves edge-to-edge sharpness, and corrects field curvature that is typically found in ultra-wide angle lenses. The lens barrel is lightweight yet robust, sealed at 11 points, designed to be weather and dust-resistant and capable of operating in temperatures as low as 14°F/-10°C.
FUJINON XF 8-16mm F2.8 R LM WR Key Features:
- FUJIFILM X Mount is compatible with all FUJIFILM X Series interchangeable system cameras
- Weather-sealed at 11 points for weather and dust-resistance; operates in temperatures as low as 14°F/-10°C
- 20 elements in 13 groups including 4 aspherical elements, 3 ED elements and 3 super ED elements
- Uses linear motors for quiet and ultra-fast AF
- Nano-GI coating applied to rear surface of two front lens elements to eliminate ghosting and flare caused by oblique light
Availability and Pricing
The new FUJINON XF 8-16mm F2.8 R LM WR Lens will be available in late November 2018 in the U.S. and Canada for USD $1,999.95 and CAD $ 2,599.99.
Special 100mm filters holder
Review
8mm
16mm
https://www.ephotozine.com/article/fujifilm-fujinon-xf-8-16mm-f-2-8-r-lm-wr-review-34345
Special Marumi filters holder
From Japanese presentation
