Products Affected
- EOS Series (DSLR and Mirrorless)
- PowerShot SX70HS
- PowerShot SX740HS
- PowerShot G5XMarkII
Multiple Canon digital cameras (EOS series and PowerShot series) contain multiple vulnerabilities listed below.
- Buffer overflow vulnerability in PTP (Picture Transfer Protocol) when processing
SendObjectInfocommand (CWE-120) - CVE-2019-5994- Buffer overflow vulnerability in PTP (Picture Transfer Protocol) when processing
notifybtstatuscommand (CWE-120) - CVE-2019-5998- Buffer overflow vulnerability in PTP (Picture Transfer Protocol) when processing
blerequestcommand (CWE-120) - CVE-2019-5999- Buffer overflow vulnerability in PTP (Picture Transfer Protocol) when processing
sendhostinfocommand (CWE-755) - CVE-2019-6000- Buffer overflow vulnerability in PTP (Picture Transfer Protocol) when processing
setadapterbatteryreportcommand (CWE-755) - CVE-2019-6001- Missing authorization vulnerability which may result in unauthorized firmware update (CWE-862) - CVE-2019-5995
Impact
- A specially crafted PTP command may cause buffer overflow, which may result in the affected digital camera being unresponsive or arbitrary code being executed by a remote attacker - CVE-2019-5994, CVE-2019-5998, CVE-2019-5999, CVE-2019-6000, CVE-2019-6001
- Specially crafted firmware by a remote attacker or unofficial firmware update may be applied without the user's consent since the user confirmation process before applying firmware update is not implemented in the software - CVE-2019-5995
Thing that we see here can be first step on killing Canon hacking activities, as some data suggest that this is exact things used to dump firmware by the team for years.
"You should give me 3 bitcoins or I will delete all the brick wall pictures in your camera"
