AMD AM4 Motherboards Selection Guide for Video Editors
  • 31 Replies sorted by
  • GIGABYTE X570
    • X570 GAMING X, $169 at https://www.newegg.com/p/N82E16813145161
      • 5x phases via real ISL6617A doublers CPU VCC making it total 10x phases, ISL69147 controller, 1x4C10N and 2x4C06N MOSFETS per phase
      • Two medium designer made alu heatsinks, without heatpipe, all phases covered. But part of MOSFETS are on back side uncovered!
      • 2 PCIe 4.0 x16 (x16/x16+x4), second slot via chipset
      • 3 PCIe 4.0 x1 slots
      • 1 M.2 (PCIe 4.0 x4 and SATA), located above top GPU slot
      • 1 M.2 (PCIe 4.0 x4 and SATA), located lower on the board
      • Realtek ALC887 Audio
      • Realtek 8111H Gigabit LAN
      • Absolutely no USB 3.1 Gen2 ports, horror
      • No USB 3.1 Gen2 internal connector
      • 6 SATA ports
      • 128Mb BIOS Chip
    • X570 AORUS ELITE, $199 at https://www.newegg.com/p/N82E16813145160
      • 6x phases via real ISL6617A doublers CPU VCC making it total 12x phases, ISL69147 controller, SiC634 50A VRPower Integrated Power Stage per phase
      • 2 PCIe 4.0 x1 slots
      • Realtek ALC1220 Audio
      • Intel I211AT Gigabit LAN
      • Two USB 3.1 Gen2 ports, 2xType A, via chipset
      • One USB 3.1 Gen2 Type C port via internal connector
      • 6 SATA ports
      • 128Mb BIOS Chip
    • X570 AORUS PRO WIFI , $269 at https://www.newegg.com/p/N82E16813145157
      • 6x phases via real IR3599 doublers CPU VCC making it total 12x phases, IR35201 controller, IR3553 integrated PowIRstage for each phase
      • Two medium heatsinks one with actual fins, with heatpipe, all phases covered.
      • 3 PCIe 4.0 x16 (x16/x8+x8) and x4 from chipset
      • Three USB 3.1 Gen2 ports, 2xType A + Type C, via chipset and CPU
      • 6 SATA ports
      • 2x128Mb BIOS Chips
    • X570 AORUS ULTRA, $299 at https://www.newegg.com/p/N82E16813145156
      • 1 M.2 (PCIe 4.0 x4), located above top GPU slot
      • 6 SATA ports
    • X570 AORUS MASTER, $359 at https://www.newegg.com/p/N82E16813145155
      • 6x phases via real IR3599 doublers CPU VCC making it total 12x phases, IR35201 controller, IR3556 integrated PowIRstage for each phase
      • 1 PCIe 4.0 x1 slots
      • Realtek ALC1220 + SABRE9118 DAC Audio
      • Realtek RTL8125 2.5 Gbps LAN
      • Four USB 3.1 Gen2 ports, 3xType A + Type C, via chipset and CPU
      • 6 SATA ports
    • X570 AORUS XTREME, $699 at https://www.newegg.com/p/N82E16813145158
      • 14x phases CPU VCC, IR XDPE132G5C controller, TDA21472 integrated 70A power stage for each phase
      • Two medium heatsinks, both with actual fins, with heatpipe, all phases covered.
      • Realtek ALC1220 + SABRE9218 DAC Audio
      • Aquantia AQC107 10-Gigabit LAN
      • Six USB 3.1 Gen2 ports, 5xType A + Type C, via chipset and CPU
      • 6 SATA ports
  • All X570 major manufacturers boards added.
  • Can compare completely nuts approach with one of most full featured x399 HEDT boards - •Fatal1ty X399 Professional Gaming
    While VRM is not so much overkill like top boards here, but connectivity (M.2 slots and PCIe slots) and network are superior to any >$600 boards here.
    And it is $390 new and around $300 used.
    https://www.personal-view.com/talks/discussion/21511/amd-tr2-x399-hedt-motherboard-selection-guide-for-video-editors#Item_18
  • Biostar made bios for 4xx chipsets with PCIe 4.0
    Biostar activated the functionality on four of the brand's AMD 400-series motherboards.
    • X470GT8 Motherboard and new X47AG718.BST BIOS
    • X470GTN Motherboard and new X47AK718.BSS BIOS
    • B450MH Motherboard and new B45CS718.BSS BIOS
    • B45M2 Motherboard and new B35GS718.BSS BIOS
  • MSI started making motherboards with 32Mbit BIOS
    • X470 GAMING PLUS MAX
    • X470 GAMING PRO MAX
    For now do not see better boards in the list.
    All else are lower end boards.
  • The new AGESA code with number AM4 1.0.0.3 ABB from AMD is made with sole purpose - disable working PCIe 4.0 for motherboards where manufacturer enabled this feature.
    As this feature showed that all marketing lies about 6 layer server class boards required (while in reality most <$300 ones are still same 4 layer things), just top management of motherboard manufacturers planned big bonuses at your expense.
    Note that AGESA is fully closed and encrypted AMD code residing in BIOS.
