Panasonic has announced the launch of its Lumix S loan scheme, where photographers and videographers can sign-up for a two-week loan of Lumix S Series kit free of charge.
The LUMIX S loan scheme is open to all professional and high-amateur photographers and videographers who are interested in trying out the S Series kit for their general work or an upcoming project, providing an excellent opportunity to try out the system properly before committing to purchase.
To sign up for a loan, visit the Panasonic website.
"Improved AF performance : [AF-ON: Near Shift] and [AF-ON: Far Shift] functions have been added. [AF-ON: Near Shift] preferably focuses on a subject nearby while [AF-ON: Far Shift] preferably focuses on a subject far away."
I wonder if this Panasonics attempt to try and stop the "hunting" that happens with their existing CAF mode. So when the camera is set to only focus on close by subjects it won't then attempt to focus shift onto the background like it does at present.
Firmware Version 1.1
Nauticam NA-S1R Housing
Preorder (if you are owner already - pause for a while!)
https://www.bhphotovideo.com/c/product/1480752-REG/panasonic_dmw_sfu2_lumix_s1_filmmaker.html
UK PR on firmware
Functions available within the upgrade programme include:
- 14+ stops of V-Log recording
- World’s first 4:2:2 10-bit 4K MOV 30p/25p1 internal video recording2
- World’s first 4:2:2 10-bit 4K 60p/50p1 HDMI output2
- V-Log and V-Gamut compatible with Cinema VariCam Look
- In-camera LUT (Look Up Table) application enabling playback of V-Log while or after recording (LUT Display with Custom Function)
- A WFM (Waveform Monitor) displays brightness level while recording
- High-res 48-kHz/24-bit or 96-kHz/24-bit sound can be recorded in MOV using the XLR Microphone Adaptor DMW-XLR1
The upgrade key will be available free of charge by redemption from 8th July 2019 for existing purchasers of the LUMIX S1, and new purchasers until 30th September 2019. From 1st October 2019 the key will be available to purchase at £179.00.
UK and Ireland only. Full terms and conditions apply. For further information visit www.promotions.panasonic.co.uk
First discounts start in US, for starters as trade-in stuff
https://www.bhphotovideo.com/c/promotion/15307/panasonic-trade-in.html
The linear function has it's own set of issues. I do lots of filming at long distances and in linear mode regardless of rotation range selected, it is almost unmanageable out toward infinity focus. You simply can't control it finely enough to hit critical focus. The non-linear mode allows ultra fine adjustment when out closer to infinity focus and is much more useful for a lot of the wildlife and landscape work I tend to do most often. With a focus ring clutch like the new 50mm it might be more useful but on the 24-105, I found it to be much worse than than the non-linear mode I've become accustom to and actually prefer.
Cheers, Pete
This same thing must be made as firmware update for all m43 lenses. Not sure if it'll work perfect, but at least it'll be better.
