11-20mm T2.9 Tokina Cinema ATX
    Features
    The Tokina Cinema ATX 11-20mm T2.9 Wide-Angle Zoom Lens (EF Mount) features a super-wide field of view and cine-style design elements. It covers Super 35mm image sensors and is a parfocal lens, holding focus throughout zoom moves. The Cinema ATX 11-20mm maintains a constant T2.9 aperture throughout its zoom range, eliminating the need for exposure compensation as you zoom in. Its durable metal housing withstands the rigors of cine production and incorporates 0.8 Mod lens gears for compatibility with FIZ (focus/iris/zoom) control systems.
    Interchangeable LPL, PL, Sony E, MFT, and Nikon F lens mounts are available separately for swapping with the EF mount, expanding the lens's compatibility with additional cameras. The Tokina Cinema ATX 11-20mm incorporates low-distortion glass, and its 9-bladed iris produces attractive bokeh in out-of-focus areas. Focus (feet), iris, and zoom settings are marked on both sides of the lens barrel.
    Additional cine features include a minimum focus distance of 12", 300° of focus rotation, and an industry-standard 95mm front diameter compatible with most pro-style matte boxes. An 86mm front thread provides a second filtration option especially useful for low-profile or lightweight rig configurations.
    Note! Lens mounts may be changed by the user but mounting by a lens service center is recommended to ensure accurate focus scales.
    • Compact, wide-angle T2.9 zoom lens covers Super 35mm sensors
    • EF mount is interchangeable with separately available PL, LPL, MFT, Nikon F, and Sony E mounts
    • Cine-style 0.8 Mod lens gears are designed for use with FIZ (focus, iris, zoom) systems
    • A constant T2.9 aperture is maintained throughout the zoom range
    • Low distortion glass
    • 9-bladed iris for precise exposure control and attractive bokeh
    • 12" minimum focus distance enables wide but close shots
    • Parfocal lens design maintains focus while zooming
    • The 95mm front diameter fits most pro-style matte boxes and adapters
    • The all-metal, cine-style housing includes a front 86mm filter thread
    • Focus (feet), iris, and zoom marks are on both sides of the lens barrel
  • 3 Replies sorted by
  • very interesting on paper because it’s a parfocal lens.
