Z Camera E1 Mini m43 4K camera for $199 only, cheapest 4K ever
  • 270 Replies sorted by
  • New app coming too....? !!!!
    606 x 262 - 53K
  • @CFreak
    I hope they do it before 25th.
  • Btw how soon they start doing proper Android app? Matching iOS?
  • They aren't talking about Android at all.
  • More porn
    Power board
    Front assembly with sensor
    Main board area
    You can see empty place from damaged part near green dot, and lot of empty spaces originally present on board
    800 x 609 - 74K
    800 x 612 - 69K
    800 x 656 - 120K
    800 x 765 - 179K
  • For now do not see any updates still.
  • FW 0.31 is out.
    The FB page has a link to google drive. It's not on the official page ...yet? It would be best to wait until it's on the official page or join the FB page "ZCAM E1 Users"
    630 x 815 - 118K
  • @CFreak
    It is all so similar to Yi M1 one year ago. Up to the point where they assume Facebook being center of universe.
    And I guess it is last ever firmware update.
  • Hi! I'm thinking to buy a second hand Z-cam E1 for fast timelapse and maybe for a 360° photo rig. I didn't find the user manual.
    It seems photo timelapse is limited to 1s interval. But is it possible to shoot faster with external control ? Not burst mode with exposure locked, I need metering for each images. I'd like to take 2 or 3 pics per second.
    An accurate timestamp is useful when you want to geolocalize images with a gpx trace. But I don't know if this cam store the subsectimeoriginal exif value to complement the DateTimeOriginal.
    Could a E1 owner help me?
    Thank you in advance
  • Hey!
    I've been working on 0.31 E1 firmware for 1 week and got some results. Now I can shoot DCI 4K with ~80 Mbps. But I can't go higher because of very strange bug - when I set bitrate higher than 0x03E7FFFF, all become a mess and I don't know what is this. Can you give me any advice?
  • @storyboardcreativity
    Can be anything, from other parameters limiting normal work to hardware limits.
  • @Vitaliy_Kiselev
    E1 is based on Ambarella A9 - does it have hardware limits?? Maybe somebody has already done hacking bitrate on any other A9 camera? As I know, H264 is encoded in this SoC by hardware DSP. This bug seems not like overflow.
    Check Xiaoyi YI 4K Action Camera hacked firmwares.
  • @Vitaliy_Kiselev
    "Check Xiaoyi YI 4K Action Camera hacked firmwares" - checked a week ago, didn't help me.
    Good news! Just reached stable 100 Mbps in 24 fps 4096x2160. As bitrate is limited to 0x3E80000 (65536000 bits per second) by unknown magic, I switched mode in code from CBR to VBR and set min and max percents to do bitrate at 160% from average. Now I set bitrate to 0x3E7FFFF (65535999 bps) and get bitrate around ~104857598 bps (~100 Mbps).
    Higher percents make camera freeze in ~5-6 seconds after recording start (I think that because of SD card bus). Do you know any variants to overclock micro-sd? :D
  • Higher percents make camera freeze in ~5-6 seconds after recording start (I think that because of SD card bus). Do you know any variants to overclock micro-sd?
    No :-)
    But again, check all other Ambarella firmwares hacks, as controller is 100% same.
    It can be also your card.
    Also try to publish modified firmware and provide here link. Even for unfinished hacks.
  • @Vitaliy_Kiselev
    Also just reduced GOP size to 1 (now get Intra frames only). Works fine and stable.
  • @Vitaliy_Kiselev
    I think, it's time for me to create a github with all I have. To make changes in firmware I use autoexec.asc that is started by ThreadX RTOS at each time camera powers on (there are commands, that allow to make changes in code memory). As for me, it's better than update firmware each time and be afraid to get bricked camera :D
    Z Cam E1 has 2 operating systems on board: ThreadX RTOS and Linux. RTOS is for all hardware communications, recording, accessing to H264 DSP and all other stuff. Linux is for UI and uplevel scripts. GUI is made in Qt. Each time we do smth in UI it sends a message to RTOS through a socket.
    Nice.
    One thing that can propose is to use your own server (cheap VPS will do) and https://www.fossil-scm.org/index.html/uv/download.html (it provides all interface also).
    Github repository can be wiped (with all other of your repositories and all account) in seconds out if company won't like something.
  • @Vitaliy_Kiselev
    Thank you, I'll think about it.
    Do you know anything about MN34230 sensor (sensor from GH4 and that's used in E1)? As I see, 1280x720 120fps and 240fps seem like garbage. It's NOT because of H.264 encoder - I've unlocked MJPEG and result is the same - very unsharp frames (seem like upscaled with sharpen filter).
  • From ZCAM Facebook page Aug 2018 : Three ZCAM E1's on set with Reese Witherspoon image
    1680 x 1120 - 272K
    1680 x 1120 - 337K
