Topic solely for selection of ITX motherboard for AM4 Ryzen CPU based storage system.
Focused on small teams and individual video editors needs.
I'll be adding systematic info post by post.
Ideal modern storage ITX motherboard must allow:
CPU info and limits
Ryzen is gaming/consumer CPU with some IO shortcomings by design, not so important for ITX boards.
Note! Ryzen 2200G or 2400G are designed such way that they provide only 8 PCIe 3.0 lines to GPU instead of 16x and they can't be split. All else is same. For ITX case it is not so important.
Chipset difference and motherboard limits
For ITX boards difference is extremely small, if exist, as usually it is only one PCIe slot, and bifurcation can be actually enabled on some boards even with B350/B450 chipsets and disabled on others using X370/X470 one.
Note that some motherboard can refuse to boot without GPU installed (if you use CPU without such) and this also is BIOS version dependent.
I'll try to add this info later.
Gigabyte
MSI
ASUS
List of all B350,X370, B450 and X470, only ITX sized motherboards
I do not include Biostar here.
Red - something not good or missing feature.
Blue means - ok or average.
Teal - above average.
Green - really good for us.
AsRock
Wi-Fi adapters removal to add up to 4 extra SATA ports
It gives you one extra M.2 slot, very important with such big constrains.
This is how it looks at ASRock ITX boards:
Note that it is unusual Key E slot
Adapter
As connector on board is E key so you may need to modify M.2 side of adapter to fit in slot.
SATA controllers:
ASMedia 1061 controlled based, supports port multiplier (see below).
Price is around $20.
https://www.aliexpress.com/item/Mini-PCI-Express-SATA-3-0-Controller-Card/32329921426.html
Marvel 88SE9215 controller based, supports port multiplier (see below).
Price is around $36.
https://www.aliexpress.com/item/IOCREST-4-Port-SATA-III-6G-Mini-PCI-Express-Controller-Card/32814284199.html[https://letyshops.com/r/aliexpress-1s642idt1fok8o]
What is SATA Port Multiplier?
It is board that looks like this.
Around $19
Preferably you need one based on JMICRON JMB575 as it is SATA 3.0.
Note - port multiplier need support from main SATA controller and it's drivers.
Most Intel consumer chipsets dropped this support long time ago to avoid competition.
I can't find information about modern Ryzen chipsets made by ASMedia.
Such multipliers are also used inside many storage rackes connected via USB.
Another usage of M.2 slot
Extra network controllers.
One port Gigabit for $15
Two ports one for $30-35.
OS to use
Preferably use Windows Server 2016/2019.
From Windows 10 it is preferable to use Pro for Workstations edition.
You will need RDMA and SMB Direct if you use remote file work with fast network adapter (10Gbit and more).
