January 7, 2018 – DJI, the world’s leader in creative camera technology, introduced two new handheld camera stabilizers at CES 2018 – Osmo Mobile 2 and Ronin-S. Built for smartphones, DSLRs, and mirrorless camera systems, they give consumers, professional videographers and photographers new tools to capture smooth, steady videos and stunning photos wherever they go.
Ronin-S: DJI’s first single-handed stabilizer for DSLR and Mirrorless Cameras. Built for efficient setup and ease of use with a compact form and dedicated buttons to control camera settings and precise positioning, plus intelligent features for advanced shooting modes all designed to help bring a steady shot to any set.
“With the introduction of these two stabilizers, DJI now offers gimbal technology to help unlock the creative storyteller in everyone no matter what camera they’re using,” said Paul Pan, Senior Product Manager at DJI. “Osmo Mobile 2 offers the best in smartphone stabilization at an affordable price, and Ronin-S brings the quality of DJI’s professional gimbal technology to a new form factor that is perfect for run-and-gun filming using your favorite DSLR or mirrorless camera system.”
Ronin-S – Bring a Steady Shot to Any Set
Ronin-S is DJI’s first single-handed stabilizer for DSLR and mirrorless camera systems. Available in two frame sizes for either camera type, DJI’s powerful three-axis gimbal technology delivers smooth, shake-free video and crisp photos, adding a cinematic and professional look to your work.
Powerful high-torque motors support the most popular camera and lens combinations including the Canon 5D, Panasonic GH and Sony Alpha systems. Its stabilization system compensates for zoom lenses with higher magnification ratios and an external zooming barrel, while its advanced stabilization algorithms work with both in-camera and in-lens optical stabilization technology.
Capturing stabilized video has never been easier because Ronin-S was designed for easy setup and use. A new Push mode lets you adjust the pan and tilt axis by hand while the Ronin-S is powered on and axis locks speed up the setup process so you can spend more time filming and less time prepping your gear. Ronin-S has a comfortable, ergonomic curved design that helps capture smooth cinematic movements from upright to underslung positions without obstructing the camera’s display. Ronin-S also features DJI’s intelligent battery technology that can be hot-swapped during operation for extended shoots.*
Dedicated control buttons for the camera and gimbal let you toggle between SmoothTrack settings, record and stop the camera, and the high-precision joystick changes the camera position to help frame your shot perfectly. A new Sport mode allows for fast movements with tight and quick subject following speed.
Harness intelligent shooting modes on Ronin-S through the DJI Ronin mobile app to create complex camera moves automatically like Panorama, Hyperlapse, Track and CamAnchor that lets you designate specific camera positions in a scene and rotate between them on demand. Directly customize SmoothTrack settings with dedicated controls for responsiveness of each axis. Camera settings can be directly adjusted as well.**
Ronin-S is compatible with a variety of DJI Pro Accessories to capture any scene and expand your creative freedom on set or location. Supported accessories include a Focus Control Center consisting of a focusing dial and a screen allowing advanced gimbal and focus control without a mobile device, a vehicle mount solution, DJI Master Force, DJI Master Wheels, an external focus motor, and a cheese plate adapter so you can use your favorite third-party accessories. A dual-handle support will also be available for when an added level of comfort and stability is required.
Price and Availability
Ronin-S will be available in the second quarter of 2018 from dji.com, DJI Flagship Stores, DJI Authorized Retail Stores, and DJI Resellers worldwide***. Pricing will be announced prior to availability. Additional information on Ronin-S can be found at www.dji.com/ronin-s.
DJI Ronin-S Essential Kit sale for $348
https://www.bhphotovideo.com/c/product/1462664-REG/dji_cp_rn_00000033_01_ronin_s_essentials_kit.html
Lanparte has released the Ronin S L plate for vertical shooting. It enables the user to switch to vertical shooting easily and quickly for doing videos for Instagram, Facebook, Twitter, TikTok, etc.
The bracket is a customized unit which fits the DJI Ronin-S gimbal for vertical shooting with is popular with social media. The camera can be mounted on the bracket on the vertical axis and can be bracket can be mounted on either side of the plate for left or right mounting. The user can remove the camera from the gimbal in seconds because of the ARCA mount. The mounted camera then can be put horizontally on a tripod that is ARCA compatible.
The high quality hollowed out triangular design reduces the weight of the bracket and makes the bracket light and strong. There is a ruler on the bottom like the original plate and anti-skid rubber. The plate does not interfere with the gimbal motor. Also the Ronin-S original control cable can be used. Lanparte supplies 3 counterweights for heavier cameras which include most DSLR’s and mirrorless cameras for a better balance.
Clears camera strap connectors
Active Track 3.0 is rather useless for pro work in my opinion, as beside setting it to fast/slow it can not be adjusted and it does allow the object to move relativly far to the side before it pans in both settings. So the resulting footage looks like filmed by a camera man half asleep. Add the hassle of completly rebalancing the whole system to far off values if you add the mobile on top of the cam (and balancing back to normal if you remove it) makes this quite a bummer. Might work out if you crop some in post and do some additional tracking on the object.
Force Mobile on the other side is just amazing. I have a HDMI transmitter and Tilta Nano remote follow focus motor attached to the cam on gimbal. When you hold the monitor with receiver, mobile and tilta focus wheel attached to it, you can pan,tilt and focus VERY intuitive. It pretty much feels as if you would turn the cam directly, with just a little latency, and smoothed out. This adds quite some value to the gimbal, as it allows to create really natural looking pans when mounted on crane or gib. It needs to recablibrated to recenter after each take, but you do not feel this while paning, as you only see the picture on screen, and have no reference. This is really amazing.
ActiveTrack 3.0
New firmware features
I wonder if there is a cable to extend the 8 pin port on the gimbal, so one can mount the focus wheel on a dual handle.
I am trying to pair the Ronin S with a 4th-Axis Stabilizer and a Ready Rig.
https://www.amazon.com/dp/B07FMXWTKP
Some other questions that swirl around in my head: I red that you can not control focus via Sbus. Is this true? What about CAN Bus? Are there in general any information available about the DJI protocols?
DJI Ronin S
DJI, the world’s leader in creative camera technology, today introduced nine new accessories for Ronin-S, DJI’s first single-handed stabilizer for DSLR and mirrorless camera systems, helping capture stabilized video easier than ever before. From a brand new external focus motor to pull focus on lenses manually to the Command Unit offering quick access to settings, Ronin-S users now have a host of exciting new tools to help capture their creative vision.
The DJI Ronin-S Focus Motor brings control to manual lenses that do not have internal adjustment. Utilizing the Ronin-S Focus Wheel, operators have the option to position the new Focus Motor on the focus ring to quickly adjust while filming. Seamless and precise control over the lens is easily achieved thanks to .02 degrees of accuracy. The Focus Motor includes two essential components, a Rod Mount Set which mounts the Focus Motor to Ronin-S and the Focus Gear Strip that fits around a wide array of lenses. The Ronin-S Focus Motor allows for precise control over a wide variety of lenses and expands the creative freedom for professionals.
For operators who need to control Ronin-S in fast moving situations, the Command Unit brings quick access to Ronin-S through a compact and bright screen that attaches to the side of Ronin-S. Vital settings such as motor parameters, remote control, operation modes and more can easily be adjusted without the need of a mobile device.
The Ronin-S BG37 Grip powers Ronin-S via a 2400mAh built-in battery, offering up to 12 hours of use, designed to meet the needs of camera professionals who are seeking tools for extended shoots.
A new Top Hotshoe Bracket securely mounts a DLSR camera to the Ronin-S, perfect for shooting scenarios when mounting the gimbal to a vehicle to shoot car chase scenes or fast-moving objects. It also comes with a cold shoe mount that allows users to mount external accessories during operation as well as an additional mounting point for the Ronin-S Focus Rod mount.
This Extended Lens Support is designed for use with both standard sized cameras as well as larger camera systems. With a relatively wide adjustable range, the Extended Lens Support helps to firmly secure the camera on the Ronin-S and ensure more optimal shooting performance when the included support is not long enough.
The Ronin-S Universal Mount allows users to mount Ronin-S to a car, a jib, a cable cam system and more. Power Ronin-S via the two independent DC-IN ports with a Dual TB50 Battery Mount, a high performance DJI battery system sold separately or any 12-17V power source.
The External GPS Module offers more stability during fast acceleration and deceleration when shooting with Ronin-S, for smoother videos and the ability to hold a level horizon better. The GPS signal provides more responsive gimbal stability that can react to sudden movements, enhancing the overall user experience.
Kinotika did a pretty long DJI Ronin-S vs. Zhiyun Crane 2 shootout. Surprisingly jittery showing from the Crane.
PR
DJI, the world’s leader in creative camera technology, today revealed the pricing and availability of the Ronin-S, DJI’s first single-handed stabilizer for DSLR and mirrorless camera systems. The Ronin-S will retail for $699 USD with pre-orders beginning May 29 at www.dji.com, DJI flagship stores and authorized dealers worldwide, with shipments starting in late June.
About the Ronin-S
Utilizing DJI’s powerful three-axis gimbal technology, the Ronin-S delivers smooth, shake-free video and crisp photos, adding a cinematic and professional look to your work.
Powerful high-torque motors support a payload of 8 pounds to accommodate the most popular camera and lens combinations including the Canon 1D and 5D, Panasonic GH and Sony Alpha series. Its stabilization system compensates for zoom lenses with external zooming barrels and higher magnification ratios, while its advanced stabilization algorithms work with both in-camera and in-lens optical stabilization technology. When mounted to a vehicle, the maximum operation speed has been tested at 47mph with a Panasonic GH5 and 50mm lens utilizing an optional top hotshoe bracket.
Capturing stabilized video has never been easier because the Ronin-S was designed for easy setup and use. A new Push Mode lets you adjust the pan, tilt and roll axis by hand while the Ronin-S is powered on and an Auto Tune function automatically adjusts the strength of the motors to speed up gear prep so you can spend more time filming and less time setting up your gear. The Ronin-S has a comfortable, ergonomic design that helps capture smooth cinematic movements from upright to flashlight mode to underslung positions without obstructing the camera’s display. Ronin-S also features DJI’s intelligent battery system that is built into the handle and has an operating time of 12 hours.
The high-precision joystick changes the camera position to help frame your shot perfectly while a host of dedicated buttons allow operators to control various settings such as toggling between SmoothTrack profiles or to begin and stop recording.* An included Focus Wheel can be mounted to either side of the handle via the 8-pin ports on each side and a new Sport mode allows seamless transitions to fast movements with tight and quick subject following speed.
Harness intelligent shooting modes and advanced customization on the Ronin-S through the DJI Ronin mobile app such as creating complex camera moves automatically like Panorama, Motionlapse, Timelapse and Track that lets you designate specific camera positions in a scene and rotate between them on demand. Operators can also change SmoothTrack settings including the Speed, Acceleration and Deadband for each axis, save them in three profiles and toggle between them with the dedicated M button on the Ronin-S. Vital camera settings can be directly adjusted via the Ronin app and the optional Focus Command Center accessory allows for quick changes when needed.*
Ronin-S uses an industry standard Manfrotto quick release system and is compatible with a variety of DJI Pro Accessories to capture any scene and expand your creative freedom on set or on location. Supported optional accessories include a Focus Command Center consisting of a menu screen allowing for advanced gimbal, camera, and focus control without a mobile device; DJI Force Pro; DJI Master Wheels; the Ronin 2 remote controller; and an external focus motor for manual lenses that pairs with the included Focus Wheel. The Ronin-S can also be used with the DJI vehicle mount, jib mount and the dual-handle system for when an added level of comfort and stability is required.
The Ronin-S firmware that supports camera parameter control will become available in early July.
PR
NEW YORK, May 29, 2018 (GLOBE NEWSWIRE) -- B&H Photo would like to share the official announcement of the DJI Ronin-S 3-Axis Gimbal Stabilizer, a lithe, single-handed tool used to smooth movement when shooting video with a DSLR or mirrorless camera. DJI is daring us to move, and the Ronin-S makes that dare easy to accomplish with its clean and high performance, for camera systems weighing up to 7.9 lb. It also offers one-handed design, enabling simple, intuitive operation, and a slimmer profile for working in confined spaces with ease.
Among the major advantages provided by the Ronin-S is a design that moves the roll axis to a 45-degree angle, ensuring there is a clean line of sight to the camera's rear screen for monitoring purposes. Also, it is a part of DJI's constantly growing ecosystem, and will offer immediate support for plenty of their accessories, including the Master Wheels and Master Force. It has a dual handle system, multiple types of wireless receivers, a focus control setup, and more. Also included are standard mounting points for attaching useful tools like microphones and lights.
Three operational modes are available for added versatility--underslung, upright, and flashlight. Each of these is determined by the desired grip and angle of the shot, and make it more comfortable to operate for longer periods of time. The gimbal can even be removed from the handle and mounted on other supports, such as a jib or RC car, for which there is a dedicated mode to ensure silky smooth motion. A Sport Mode can be enabled for moments of fast-paced action.
DJI Ronin S
Product Highlights
- Three-Axis Motorized Gimbal Stabilizer
 - Holds DSLR or Mirrorless Cameras
 - Offset Roll Motor for Screen Visibility
 - One-Handed Operation
 - Interchangeable Parts Ecosystem
 - Accessory Dock
 - Customizable Parameter Groups
 To provide an excellent operating experience, the Ronin-S offers multiple control options, including a precise joystick located on the handle, with multiple customizable parameters. Users will enjoy support for camera control as well, with the ability to connect to select Canon, Sony, Nikon, and other systems where they can adjust focus settings, initiate recording and more without taking their hands off the Ronin-S. Other settings include a Virtual Joystick option, Time-Lapse, Track, and Panorama modes.
A wide range of movement is possible with this gimbal, including continuous 360 degrees of rotation, tilt from -95 to 185 degrees, and a complete 360 degrees of roll in a Roll 360 mode that will come in handy for rapid movement and repositioning of your camera. Additionally, it is powered by a rechargeable 18650 2400mAh Li-ion polymer battery pack that will operate for hours on a single charge, while Bluetooth 4.0 and USB Type-C connections permit the stabilizer to be connected directly to mobile devices and computers.
The DJI Ronin-S will be exclusive to B&H Photo for a limited time. It is already open for pre-order, and will soon be available.
