V2.2 firmware
New functions are added in Fn button. The option "Wireless Setup(Flash)" has been added to [Setting in REC mod] on the [Fn Button Set] of [Custom] menu.
The option "Wi-Fi" and "LVF/Monitor Switch" have been added to [Setting in PLAY mode] on the [Fn Button Set] of [Custom] menu.The phenomenon that rarely freeze at the time of tracking AF usage is improved
http://av.jpn.support.panasonic.com/support/global/cs/dsc/download/fts/index2.html
On assignment, I like to work fast, but what I don’t like to do is fumble with a camera. As I began to really work with the GX8, I found that the size of the camera was an advantage, but for how I work, it needed a bit of help. If you ever worked with a GH4, you’ll notice how damned comfortable a camera it is for its small size. The grip on the GX8, however, is a bit sharp on edge where your fingers wrap around to the front of the body. I believe this choice is more form than function as it appears to be shaped for someone that might have their human hand replaced with a giant lego hand.
http://www.giuliosciorio.com/creators-path/2016/7/10/lumix-gx8-long-term-review
I think this is a good footage in night low light situation. With images very clean.
After a few days of companionship the Panasonic Lumix GX8 had proved to be a very solid still camera. Its larger size will give you confidence to bring it everywhere on every circumstances even in bad weather.
http://photodanielm.blogspot.com/2016/08/the-panasonic-lumix-dmc-gx8-pro-still.html
Panasonic LUMIX GX8 Mirrorless Micro Four Thirds Camera (Silver), G Vario 12-60mm f/3.5-5.6 ASPH. POWER O.I.S. Lens, Transcend 64 GB Card, Polaroid Tripod, Polaroid Battery, Charger + Accessory Bundle, $997
https://www.amazon.com/Panasonic-Mirrorless-Camera-12-60mm-Lens/dp/B01HSEQRPW/
Panasonic Lumix DMC-GX8 + 25mm lens for $898 + free 3 year warranty
https://www.bhphotovideo.com/c/product/1380166-REG/panasonic_lumix_dmc_gx8_mirrorless_micro.html
