15mm F2 and T2.1 Cine Laowa Zero-D FE lens
    Venus Optics, the camera lenses manufacturer who had previously launched a number of quality lenses with ‘World’s First’ specifications, is proud to unveil two premium lenses with extreme specifications and impressive performance, the Laowa 15mm f/2 FE Zero-D & the Laowa 7.5mm f/2 MFT.
    Laowa 15mm f/2 FE is currently the World’s Fastest 15mm rectilinear lens for Full Frame cameras. It features a close-to-zero optical distortion, allowing photographers to take landscape or architecture shots with straight lines retained.
    Dedicated to fulfill the need of photographers, Venus Optics have managed to add a 72mm filter thread onto the 15mm f/2 lens. Photographers can easily install standard screw-in filters without paying for an expensive yet bulky filter holder system.
    Designed specially for the Sony Full Frame Mirrorless cameras, Venus Optics has successfully controlled the size and weight of the lens to the minimal. Weighing less than 1.1 pounds (500g) and 82mm in length, the portability and compactness of the Sony E- mount Mirrorless cameras can be maintained when used with the Laowa 15mm f/2 FE Lens.
    Featuring the fastest f/2 aperture ever built with a 15mm lens, the new Full Frame E- mount lens is engineered for professionals to shoot impressive landscape, architecture and primary astro photos with great details. This is an every-day and must-buy lens that every Sony Full Frame Mirrorless camera user should have one in his bag.
    MTF
  • 36 Replies sorted by
  • Laowa 15mm T2.1 Zero-D Cine
    Laowa 15mm T2.1 Cine provides an ultra-wide-angle coverage up to 110° on a Full Frame camera system. It is currently the widest T2.1 lens in the market covering large format sensors. The large T2.1 aperture also makes it extremely useful to shoot in low light situations. The tiny size & light weight makes it a perfect companion with gimbals and run-and-gun shooting. The new Cine version comes with standard 0.8 mod gears on both aperture and focus rings. A standard 77mm filter thread is designed to mount screw-in filters easily. The lens also features a superb optical distortion control with all straight lines retained.
    New Mount: Nikon Z
    Other mounts available: Canon RF / Sony FE
    (Product Page: https://www.venuslens.net/product/1521cine/ )
  • Venus Optics, the camera lenses manufacturer specialize in making unique camera lenses, unveiled three new ultra-wide cine lenses for cameras with different sensor sizes. They are the Laowa 7.5mm T2.1 Cine for Micro Four Thirds cameras, Laowa 9mm T2.9 Zero-D Cine for Super35 cameras and the Laowa 15mm T2.1 Zero-D Cine Lens for large format (full frame) cameras. All three lenses feature the same optical system as the their popular photography version and offer premium optical performance. They have also been built with robust cinema lenses housing with design up to the industry standard.
    Ultra-wide FoV & fast aperture
    All three Laowa cine lenses feature an ultra-wide angle of view and fast aperture. The Laowa 7.5mm T2.1 feature a 110° FoV on MFT while the 9mm T2.9 features a 113° on Super35 sensors. The 15mm T2.1 instead features a 110° FoV on cameras with full frame sensors. The fast maximum t-stop is well suited for filming under low light condition. It also allows filmmakers to have more flexibility in depth of field control.
    Close-to-zero distortion
    Both the 9mm and 15mm feature the distinguishing Laowa close-to-zero distortion (Zero-D) design where the optical distortion at infinity distance has been compressed to the minimal. This is extremely important for motion picture recording when shooting indoor, architecture or footage with straight lines included. This also saves tremendous amount of time in distortion correction in post processing.
    Compact & lightweight
    All three wide angle prime lenses are extremely compact and lightweight. Both 7.5mm and 9mm weigh close to 0.5 lbs (226g). The 15mm is a little bit heavier due to the larger coverage but Venus Optics still manage to compress it to around 1.2 lbs (540g). On the contrary to the huge and heavy wide angle lenses in the market, the new Laowa cine lenses are extremely handy for run-and-gun productions, shooting with gimbals, in-car shots, indoor scene, etc.
    Close Focusing Distance
    All three Laowa cine lenses possess an extremely close focusing distance. This provides a great deal of flexibility for directors to compose shots at any distance. Filmmakers can also take advantage of this close focusing to create some wide angle shots with shallower depth of field. Both the Laowa 7.5mm and 9mm can focus as close as 4.7" (12cm) from sensor to subject while the 15mm can focus up to 5.9" (15cm).
    Industry standard cinema lens housing
    The major difference between the new cinema version and the still version is the improved housing. The new cinema lens housing have been designed with details to facilitate filmmakers to shoot with ease. Both the aperture and focus rings have been built with industry standard 0.8 mod pitch gears for pairing up with follow-focus motors. The aperture ring is now click-less for smooth iris control. Every one of Laowa cine lenses comes with a filter thread for filmmakers to use screw-in filters and mini matte-boxes. Entire lens body is made by premium grade aluminum and build for usage in extreme environment.
    Hassel-free transportation
    An authentic hard case made by Pelican will be included with the lens to allow filmmakers to travel around for shooting with ease.
    A variety of Current & Future mount options
    The Laowa 7.5mm T2.1 Cine is available in Micro Four Thirds mount and it is a perfect companion to cameras like Blackmagic Pocket 4K, Panasonic GH5 and Z-Cam E2
    The 9mm T2.9 Zero-D Cine is available in Fuji X, Sony E mount and Micro Four Thirds mount. The Micro Four Thirds mount can cover the same cameras as 7.5mm and serve as an not-as-wide alternative to MFT users. The Fuji X mount is extremely popular among XT-4 or XH-1 shooters. The Sony E mount works really well with Sony cameras with Super35 sensors including FS5, FS7, A6500 series, etc.
    The 15mm T2.1 Zero-D Cine is designed for large format sensor with Sony FE mount available. It is best suited with Sony full frame cameras like Sony A7 series and FX9.
    New Nikon Z, Canon RF and Leica L mount will be introduced later this year and they will certain be interesting wide angle options for cameras like RED Komodo, Canon R5, Nikon Z6/Z7, Sigma FP, Panasonic S1H and more to come.
    Laowa Wide Angle Cine Lenses line-up
    Together with the Laowa 12mm T2.9 Zero-D Cine released earlier for EF and PL cinema cameras, Venus Optics currently offer four wide angle cine lenses for cinema cameras with different sensor sizes.
    Pricing & Availability
    All three cine lenses are currently available to purchase via Venus Optics official website (http://www.venuslens.net/) and authorized resellers. The US price for 7.5mm T2.1 and 9mm T2.9 is $599/pc (ex-VAT) and 15mm T2.1 is $1,199/pc (ex-VAT). Pricing varies in different countries.
  • LAOWA 15mm T2.1 Zero-D Cine
    627 x 590 - 41K
    684 x 593 - 39K
  • Venus Optics announce 2 new Laowa wide angle lenses for Nikon Z & Canon RF cameras
    Venus Optics, the camera lenses manufacturer who had previously launched a number of unique Laowa camera lenses, are proud to introduce the the Nikon Z & Canon RF mount to the world’s widest rectilinear f/2 lens (Laowa 15mm f/2 Zero-D) and the world’s widest zoom lens (Laowa 10-18mm f/4.5-5.6).
    Laowa 15mm f/2 Zero-D (Both Nikon Z & Canon RF mounts)
    The Laowa 15mm f/2 Zero-D is currently the widest f/2 rectilinear native lens for full frame mirrorless cameras. The lens falls into the Laowa ‘Zero-D’ products line-up and the patented optical design successfully minimizes the optical distortion to the lowest. This compact and lightweight lens comprises of 12 elements in 9 groups with 2 pcs of aspherical elements and 3 pcs of Extra-low dispersion elements. Photographers can also take advantage of the super close focusing distance (less than 6” from the sensor) and the f/2 aperture to create some wide angle close-up shots with pleasing bokeh.
    Despite the extreme specifications, Venus Optics have successfully minimized the size of the lens to only 1.1 lbs and 3” long. The flat front surface design allows photographers to use 72mm circular filter with ease. Unlike the Sony E variant, the new Nikon Z / Canon RF variants feature a design of 5 straight aperture blades which produce a clean and sharp 10-point sunstar rendering.
    Availability
    The new variants of Laowa 15mm f/2 Zero-D & Laowa 10-18mm f/4.5-5.6 are currently available to order and ship in the official website of Venus Optics (http://www.venuslens.net/) and their authorized resellers. Recommended Retail Price in US (without tax) is USD 849/pc for both lenses. Pricing may vary in different countries.
  • Nikon mount of this lens will be available in August.
  • Small interview with lens designer
    PR: We think your Laowa 15mm 2.0 Zero-D FE is a very interesting and versatile ultra wide angle lens with a unique focal length and maximum aperture combination, so we would like to know more about the process of designing this lens. It is Laowa’s first mirrorless design (together with the mFT 7.5mm 2.0), was the filter stack in front of the Sony sensor an issue or easily accounted for in the optical design?
    Mr. Li: I’m very glad you are interested in the Laowa 15mm 2.0 Zero-D FE. As you know, the Sony mirrorless camera bodies are extraordinarily convenient and compact. But the same cannot be said of most existing wide-angle lenses, which are huge and heavy. It takes away from the convenience of the Sony bodies. And in shooting landscape, it’s not usually possible to use filters with any ease on these large wide angle lens. Another issue which typical wide angle lenses have is that they display levels of distortion which result in extra work in post-production, especially when shooting architecture. My goal was thus to produce a small lens, which could accept screw-on filters, and has very low native distortion.
    Taking advantage of the design possibilities of the short flange focal distance of mirrorless cameras, I was able to restructure the entire design, getting rid of the conventional design concepts of wide angle lenses for DSLRs.
    https://phillipreeve.net/blog/the-man-behind-the-lens-mr-li-laowa-15mm-2-0-zero-d-fe/
    800 x 531 - 156K
    692 x 468 - 52K
