Using OCT-18/OCT-19 lenses on an M4/3 camera?
  • 48 Replies sorted by
  • spbsales does conversions methinks
  • Does anyone have any information or experience about converting Lomo OCT-18 lenses to a PL mount? I have some oct-18 lenses and the ceico7 adapter, but I'd like to see about PL mount conversions.
    It would be nice because as lovely as the Lomos are they can be a mechanical nightmare (having to oil lenses, adjusting screws, etc). Also, with a PL conversion they could possibly be used on other camera systems, as PL adapters mounts / adapters are much more common. Thanks!
  • A 35 and 50 F2 OCT-18 Lomo box arrived this weekend for me and all I can say is wow - aside from the quirky looks, its like transistor amp to valve amp for character - 3d. colour, full of life love em !
  • Nice bokeh!
  • Lomos are good, okc1(lens model)-50-1(konvas 1m, oct18 mount). resolution is 72 lines per mm, earlier designs means softer lens, later design okc8 , okc11 are more sharp. I have ciesco7 oct18 adapter, excellent quality, get an ir cut filter schneider/b&w/heliopan.
    This photo is okc8-35-1 with pen epl-1
    4032 x 3024 - 668K
  • @starstuff
    Yeah, I gathered he would be but thanks for the heads up.
  • @RJH
    PerryWilson is banned, he won't reply.
  • @MomentOfTruth
    Thanks, I shall pop into some hardware stores and see what they have.
  • thin tool oil works well on my lomos... find it at hardware stored it is used primarily for lathes
  • @PerryWilson
    You use thin tool oil for lubricating the barrel of your lomo's? I need to try that as my lenses are pretty stiff. Are there any brands you can name or do I just look for "thin tool oil" It may sound like a silly thing to say but i've never heard of it and google isn't helping me too much so if you can point me in the right direction that would be great :)
  • Re Eyemo lens adaptors
    [Edit] Rykas has since replied, "I think it would be possible to make an adapter for MFT system. I don't know exact technical details of Eyemo cameras so you would have to send me one lens in order to make measurement".
    The reason I raised it here is that the Lomo oct-18 mount looks quite similar to Eyemo!
  • Apparently, Duclos can convert Lomos as well.
  • @PerryWilson How did you cine convert your lomos? Did you get someone to do it for you?
  • Looks like a great full-sensor solution. I have written to Rykas of Ceico because I have a few Eyemo lenses I'd like to try on my GH2. - these include later (ex NASA) General Scientific coated 25mm and 150mm. Do Eyemo-M4/3 adapters exist?
  • @jweeke
    Well, a good seller ought to mention that it is OCT-18. Here's a good descriptive listing: http://www.ebay.com/itm/OKC8-35-1-35-2-lens-movie-camera-Konvas-1M-OCT-18-/270841942604?pt=LH_DefaultDomain_0&hash=item3f0f70124c
    Observe the first pic (lens at its side). It's mostly smooth rounded, with one small slit at the rear.
    It's very different from OCT-19 where it has four "edges" that protrude out at the rear:
    1024 x 683 - 77K
    683 x 800 - 182K
    800 x 795 - 179K
  • Any tips on how to identify OCT-18s on ebay?
  • here is lomo stuff...
  • @zcream: Well he'd sold the lenses and only had the body, so I decided not to...
  • Konvas 1m + 3 lenses for 300/- is a great deal. Does your seller have anymore left ?
  • yeah the focus marks are correct, also I havent used oct 19 lenses I know some people like them and some people dont... different glass coating and elements... but CONGRATS and I would show you my setup but im in the process of cine converting them
  • Glass was fine, so no problem there.
    Do you have a picture that I could look at to see your follow focus rig?
    Oh and are the distance numbers correct?
    SCRATCH THAT!
    I just won a set of a 22, 35 and 50 (all T2.4) set of OCT19 lenses. But I figure that Ciecio7's adapter is still the best, right? Also, the focus marks should be correct?
  • no hassle... always have thin tool oil for the barrel so the focus is smooth
  • be sure the glass is clean, fungus free, and everything is smooth... FUNGUS CANNOT BE REPAIRED... NO MATTER WHAT ANYONE SAYS!!!... Ciecio7 adapter is THE BEST... other than those things... I shoot ONLY LOMO oct-18 and wont ever look back
