Panasonic Lumix DC-GH5S First Impressions Review: https://www.dpreview.com/reviews/panasonic-lumix-dc-gh5s-first-impressions-review
Panasonic announces Lumix DC-GH5S, an even more video-focused GH5: https://www.dpreview.com/news/4183659664/panasonic-announces-video-focused-lumix-dc-gh5s
Panasonic Lumix DC-GH5S vs Sony a7S II low light shootout: https://www.dpreview.com/videos/6914756562/panasonic-lumix-dc-gh5s-vs-sony-a7s-ii-low-light-shootout
A random ISO test:
Ok, i stopped watching Nicks video after 1:06, don't need to read all PR's bs. Welcome back MAR!!!
Is it a world camera? Ps. What to do with GH2@Moon7?
My my after all these non-mar years, I'm so happy :) Panny you've just sold one unit.
As expected. Gh2 like it will be 1.86x crop factor again. So I asume speed booster will benefit from it. You can achieve 1.3x crop approx with the 0.74x version.. 1.4x...well its better.
2 of this little monsters or 1 Eva1. Its the same internals some extra FPGAs on eva1 for Sdi and stuff.
About the dual native iso. I think it's achieved by the Hdr mode of the sensor, since it's a different path of circuitry and process of reading the pixels, I assume the engeniers make it possible a dual readout since it's all ready available through sensor level.
Hack this get us 12 bit video.
1 stop better LL, no change in DR. No IBIS. Pass.
Panasonic Announces the Ultimate Hybrid DSLM with a newly developed 10.2MP High Sensitivity MOS sensor Introducing the LUMIX GH5S: Exceptional Mirrorless Videography and Photography, designed and developed for professional filmmakers
- Introducing a newly developed 10.2MP High Sensitivity MOS sensor for enhanced image quality in low light:
- Allowing up to 51,200 ISO recording without extended ISO.
 - Time Code IN/OUT for easy synchronization of multiple cameras and Dual Native ISO, providing low range (400) and high range (2,500) ISO environments.
 - True “Multi-Aspect Ratio” Function in Both Photo and Video
 Panasonic is proud to introduce the new hybrid Digital Single Lens Mirrorless Camera LUMIX GH5S with expanded video recording capability and enhanced image quality. Designed and developed for professional filmmakers, the LUMIX GH5S achieves highest-ever image sensitivity and video image quality in the history of LUMIX cameras, especially in low-light situations.
Packed with big features to satisfy demanding photographers and videographers alike
The new 10.2-megapixel Digital MOS Sensor with Dual Native ISO Technology and Venus Engine 10 faithfully reproduce even dark parts of the image, allowing high ISO capture when the use of supplemental lighting may not be possible. This sensor is a multi-aspect type with a sufficient margin for realizing the same angle of view in 4:3,17:9,16:9 and 3:2 aspect ratios. The sensor also enables photo shooting in 14-bit RAW format, providing higher flexibility for professional RAW stills development workflows. When shooting in dark environments, videographers can now focus on filming that perfect shot as they no longer need to worry about noise which often results from having to use higher ISOs. The Dual Native ISO Technology suppresses noise to produce cleaner footage when taken in all light. Both videographers and photographers can now enjoy the same diagonal field of view across all aspect ratios with the True “Multi-Aspect Ratio” Function. This feature means you can easily swap between difference aspect ratios giving you the accuracy you want from your lenses, and making the process easier while producing and editing in post-production. The LUMIX GH5S is compatible with Time Code IN and OUT, like the professional camcorders, which is easy to set using the flash sync terminal and bundled conversion cable for a standard BNC terminal. This is especially important for “lip synchronization” when using multiple cameras. The LUMIX GH5S can be used as Time Code generator for other GH5S cameras and professional camcorders. The Time Code IN/OUT functionality makes a production teams job pain-free as it provides synchronization for both video and audio devices used on multi-cam productions.
The LUMIX GH5 achieved 4KUHD 60p video recording for the first time as a digital mirrorless camera in 2017.2 The new LUMIX GH5S establishes a new milestone by realizing the world’s first 4K 60p video recording in Cinema 4K (4096x2160), 3 capable of internal 4:2:2 10-bit video recording up to Cinema 4K30p and internal 4:2:0 8-bit Cinema 4K60p. subsampling commonly used for film production, for even more faithful color reproduction.4 The LUMIX GH5S also records 4:2:2 10-bit 400-Mbps All-Intra in 4K 30p/25p/24p and 200- Mbps All-Intra in Full-HD.
Continuing the LUMIX GH tradition, there is no time limit for both Full-HD and 4K video recording. The LUMIX GH5S complies with 4K HDR video with Hybrid Log Gamma (HLG) mode in Photo Style. A low-bit-rate recording mode, 4K HEVC for HLG, is available. This enables playback on AV equipment compatible with the HLG Display format, such as Panasonic 4K HDR TVs.
The VFR (Variable Frame Rate) function lets users record overcranked (time-lapse) and undercranked (slo-mo) video in C4K/4K (60 fps, maximum 2.5x slower) and FHD (240 fps, maximum 10x slower). A V-LogL and Rec.709 LUT (Look Up Table) are pre-installed in the camera, so users can play videos recorded in V-LogL without having to separately purchase a Software Upgrade Key. Four additional LUTs can be installed using the Panasonic Varicam (.VLT) file format.
DFD (Depth From Defocus) technology and ultra-high-speed digital signal processing achieve fast auto focusing of approximately 0.07 sec 6 with 12 fps (AFS) / 8 fps (AFC) in 12- bit RAW and 10 (AFS) / 7 (AFC) fps in 14-bit RAW high-speed burst shooting. In addition to a total of 225 focus areas, The options for Face/Eye Recognition, Tracking AF, 1-area AF and Pinpoint AF are available for precise focusing. The 4K PHOTO enables 60 fps high-speed capture in approximately 8-megapixel equivalent resolution.
Achieve outstanding footage in any environment, especially in low light
As a camera that excels in shooting in low light, the LUMIX GH5S boasts -5EV luminance detection performance with Low Light AF thanks to the higher sensitivity and optimized tuning of the sensor. Live Boost is another practical feature that makes it possible to check the composition even in total darkness, by boosting the sensitivity just for Live View. The magnification ratio in MF assist is increased from conventional 10x to 20x, which is convenient especially for astronomical photography. An AF Point Scope function, first introduced in the Lumix G9 and Night mode are also integrated.
In order to make the GH5S tough enough to withstand even heavy field use, it is composed of a magnesium alloy full die-cast front, rear and top frame that is not only splashproof7 and dustproof but also freezeproof down to -10 degrees Celsius. The GH5S is equipped with a double SD Memory Card slot, compatible with the high-speed, high-capacity UHS-II and Video Speed Class 90. Users can flexibly choose the recording method from Relay Recording, Backup Recording or Allocation Recording. The HDMI Type A terminal is provided, along with the USB-C Gen1 interface.
Exceptional image capture without concern
The GH5S has a large LVF (Live View Finder) with a stunningly high magnification ratio of approximately 1.52x/0.76x (35mm camera equivalent) providing smooth display at 120 fps. A high-precision, high-speed OLED (Organic Light-Emitting Diode) display features 3,680K-dot resolution and 100% field of view. In addition to dual dials, an omni-directional joystick enables more intuitive and flexible operation.
The GH5S includes Bluetooth and Wi-Fi® connectivity to offer a more flexible shooting experience and instant image sharing with easy operation. Compatibility with Bluetooth 4.2 (called BLE: Bluetooth Low Energy) enables constant connection with a smartphone/tablet with minimum power consumption. For Wi-Fi, 5 GHz (IEEE802.11ac)8 can be selected in addition to the conventional 2.4 GHz (IEEE 802.11b/g/n) for an even more secure and stable connection.
For extended battery life and a more stable hold, the new Battery Grip DMW-BGGH5 (sold separately) is available. The XLR Microphone Adaptor DMW-XLR1 (sold separately) allows high-res sound recording with an external XLR microphone.9
The Panasonic LUMIX GH5s will be available from end of February 2 and will retail for $2499 (body only).
Any questions fire away and Ill be back in 10 mins
Im shit at remembering my lines!
The original A7s also can't record 4k internally so it's worth factoring an external recorder into your price calculations if you're looking for apples->apples vs the GH5s... unless you guys are saying that used A7S II's are half the price of a GH5s - and if so, please let me know where you're shopping (the cheapest I usually see them used in decent shape is 1900ish). :D
Also note, if you are not using AF much, Sony A7S is cheaper, as good quality old FF bright glass is cheaper for starter.
@Vitaliy is right about the wireless t/c. And the Sony 7S.
Several years ago, Canon dropped the pixel count for their "Pro" CMOS sensors, and the results were decent. I expect way better from this new sensor; it's the right idea. Hoping the multi aspect will give a nice crop fact on the wides.
Too bad you can't turn IBIS on and off. Fact is, you really need IBIS sometimes, but this looks like an interesting camera. I can't see it hitting $500 for a while...
The real deal will be what the IQ in "decent" light looks like, I'm not sure I can see it beating Sony on the LL vid but you never know.
I will be going live on The Camera Store TV’s YouTube channel at 1:45 eastern standard time to talk about the camera if anyone wants to tune in!
Looks very cool, but IBIS is pretty life-changing...going to be hard to go back. I could see a GH5 and GH5s kit working pretty well, however, depending on low light performance, much the same way I currently use a GH5 and a7s.
Yes and no.
In cinema cameras frequently they can't make custom effective LSI.
So they use FPGAs with significant heat output. Especially true with red and BM.
Such chip can be 10-20x less power efficient than proper solution.
If you look at cinema cameras a big part of the bodies are typically heat sinks. The Alexa looks like almost 25% heat sink, with heat pipes off the sensor block. It seems heat = noise (it's probably more complicated).
The eva1 has a 17.2MP sensor. A m4/3 area of that is about 12MP (in 4/3). So it would seem that the pixels are around the same size on this 10MP sensor.
You don't need "another forum" :-) you need to sometimes read PV posts.
IBIS cameras always have more noise.
I thought that it was for segmentation reasons, but now I think that IBIS was stripped for thermal reasons - in another forum an usar said that in its workplace they have an industrial camera with an Starvis sensor, and that it generates a lot of heat and big heat spreaders were needed.
A built-in ND filter of some sort would have been a nice compromise to taking away IBIS - and such a low megapixel count on the sensor also means there can't be much of an ex-tele mode in 4k.
If you compare real DR at the image level, I guess 0,5 stops tops.
Marketing will be talking about pixel level I guess and pushing dual ISO.
Dual native iso seems to indicate varicam/eva1 tech in this beast. Is a little under the eva1's 14 stops reasonable?
Vk how much improvement s in DR you think we should expect here ,compared to GH5
The MAR sensor is back....? (!!!!)
