70-200mm GM review
http://photoreview.com.au/reviews/lenses/other-ilc/sony-fe-70-200mm-f-2.8-gm-oss-sel70200gm-lens
24-70mm GM in Germany dropped to 2109 EUR
Used starts at 1957 EUR
https://www.amazon.de/gp/offer-listing/B01BUAVMQY/ref=dp_olp_all_mbc?ie=UTF8&condition=all
70-200mm review
FE 70-200mm f/2.8 GM is really sharp lens. From wide open lens maintains very high sharpness in the central 2/3 of the image, and very good sharpness at the edges. It is same both at the wide end and the telephoto end, which is great. Stopping down a touch brings the edges to excellent territory, with even quite sharp corners. It’s definitely a lens that you can simply choose the aperture based on depth of field, and not worry about sharpness.
http://admiringlight.com/blog/review-sony-fe-70-200mm-f2-8-gm/
Sony FE 24-70mm f/2.8 GM vs 24-70mm F/4 ZA OSS
Sony FE 24-70mm f/2.8 GM for $2078
https://www.amazon.com/Sony-FE-24-70mm-2-8-Lens/dp/B01BESQYJW/
70-200mm Ver 03 Firmware
This update (version 03) improves AF-C (continuous AF) performance for zooming when attached to an ILCE-9 camera (requires the latest ILCE-9 system software update).
https://esupport.sony.com/US/p/swu-download.pl?mdl=SEL70200GM&upd_id=11282&os_group_id=28
More 70-200mm samples
https://www.dpreview.com/samples/8074207027/gallery-update-sony-fe-70-200-f2-8-gm
70-200mm Ver 04 Firmware
This update (version 04) resolves an issue where some products may not operate properly after updating to version 03.
Note: The lens must be attached to an E-mount body camera to perform this update. The NEX-5, NEX-3, NEX-C3, NEX-VG10, and PXW-FS7 model cameras cannot be used.
https://esupport.sony.com/US/p/swu-download.pl?mdl=SEL70200GM&upd_id=11327&os_group_id=6
70-200mm Ver 05 Firmware
This update (version 05) improves the accuracy of the contrast AF at distant shooting, making it easier to focus when the aperture is narrowed down to F11 or higher..
Review
Center sharpness at 70mm is high from f/4 to f/16, with f/22 being adversely affected by diffraction. The edges aren't quite as sharp as the center, with f/5.6-f/11 producing the sharpest results.
At long end, 200mm, center sharpness remains high through from f/4 to f/16, with f/22 being adversely affected by diffraction. The edges aren't quite as sharp as the center, with f/5.6-f/11 producing the sharpest results.
http://www.photographyblog.com/reviews/sony_fe_70_200mm_f2_8_gm_oss_review/
85mm video sample
Sony FE 70-200mm f/2.8 GM OSS Review
70mm
*200mm**
http://www.opticallimits.com/sonyalphaff/1044-sony70200f28gm
Sony FE 70-200mm F2.8 GM MTF Measurement
70mm
200mm
