New 2.1 firmware:
- [Power Save LVF Shooting] was automatically set to [1 sec]. (This makes the camera go into sleep mode in 1 sec in a standby mode.)
- Now [Power Save LVF Shooting] will be set to [OFF] when the firmware Ver.2.0 is updated to Ver.2.1. If you would like to enable [Power Save LVF Shooting], please set it on manually by selecting a designated time.
 - The parameters of picture quality adjustment in Photo Style were all set to -5 when setting the recording mode to [MP4 HEVC(AAC)]. This bug has been fixed.
- The parameters of picture quality adjustment in Photo Style will be reset to ±0 when the firmware Ver.2.0 is updated to Ver.2.1. If you would like to adjust the picture quality in Photo Style, please adjust them manually.
 - There were cases where [V-LogL View Assist] did not work, This bug has been fixed.
 - There were cases where motion pictures recorded in [AVCHD] cannot be divided. This bug has been fixed.
http://av.jpn.support.panasonic.com/support/global/cs/dsc/download/fts/index2.html
Gondor GH5 Cage and Complete Rig
shot on gh5
Vegas 15 update
- 4K, 10-bit 4:2:2 AVC files from the Panasonic GH5 camera are now supported
People need to try out the tracking box and just tap on the screen!
Just got a GH5 today and was outside testing. Seems to run a little warm compared to my GH4. Not hot but warm on the base plate and HDMI port side. Is this normal? It was 86F outside today.
DC voltage for GH cameras is higher than battery voltage, if it'll be low it'll stop working and tell about not original battery.
2A and 5A is current, and denote maximum current power supply can provide. As GH5 certainly is below 15 watts (15>7.2*2) 5A limit is more than enough.
Hey guys, I plan to extend my rig with a v mount. The v mount shall power my atomos as well as my GH5 via BLF19E DMW-DCC12 Dummy Battery DC Coupler. I was specifically looking into the Fotga DP500III Mark 3 which outputs 8V and 5A.
My question: Is that output ok for GH5 since GH5 batteries run on 7.2V and 2A. If I am not mistaking 8V is fine but I am not sure about the 5A.
What voltage and amp dies the GH5 take?
There is another solution is found not using the DC 8V of the fotga v-mount: http://www.hawkwoods.co.uk/Prods/Product/LR-13
Can anyone help on that setup? Or tell me alternatively how to power the GH5 externally?! Thanks :)
Just installed High Sierra and it STILL DOESN'T HAVE Quicktime Player compatibility with 10 bit GH5 files!!
Panasonic LUMIX DC-GH5 Micro 4/3s Digital Camera Body - Black (Open Box), $1729
^^ It appears the IBIS mightn't have been active for that test due to it switching itself off when the camera is mounted on a tripod. It was reported as a fault and Panasonic said they'll look into it.
^^^Lots of conclusions/claims, but thin on methodology, settings and results.
