Available at out deals for: $499 $468
. PR
The Irix 15mm f/2.4, both the Blackstone and the Firefly versions, is ready for sale”, announces TH Swiss Company. Starting from today, first deliveries of products have been shipped to distributors and retailers. Soon the customers will be able to enjoy the quality of Irix.
Irix 15mm f/2.4 lens is designed to deliver the best optical performance and match the demands of full frame DSLR cameras. Providing a focal length of 15mm, this new lens model is ideal for outdoor and indoor photography whether it is photojournalism, landscapes or architecture. The new special features such as focus lock, infinity click! and focus scale calibration set a new level of manual focus lens functionality. Thanks to sophisticated optical construction and special neutrino coating formula, colour aberration, ghosting and flare effects have been reduced to the absolute minimum. With a minimum focusing distance of 0.28 metre (0.92 ft) and 9 rounded shaped aperture blades, the lens stands for supremely smooth out-of-focus areas. The design of the lens allows the use of 95 mm screw-in filters at the front and gelatin filters at the back of the lens.
Blackstone, the Premium version, has durable body made with aluminium-magnesium alloy, that ensures foolproof protection of the lens, even in extreme situations. Its construction is equipped with four seals, that protect the camera mount and focusing mechanism against the dust and moisture, as well as front or side accidental water splashes. Engraved fluorescent markings enable easy read-out and operation in low light conditions.
Firefly is the standard version equipped with three seals that protect camera mount and focusing mechanism against dust, moisture and side accidental water splashes. Ergonomic focusing ring with rubber grip offers the freedom to operate with the camera. It is the most lightweight lens in its class.
Recommended retail prices are:
- 695 EUR for Irix Blackstone
- 475 EUR for Irix Firefly
Both versions are available for Canon EF and Nikon F cameras. By the end of September there will be also a Pentax K mount available.
The Irix 15mm f/2.4 lens is designed to deliver the best optical performance and match full frame DSLR cameras demands. Providing a focal length of 15mm, this new lens model is ideal for outdoor and indoor photography whether it is photojournalism, landscapes or architecture.
Innovative technology
Combining capabilities specific to analogue photography with ingenious technology and solutions, the Irix 15mm f/2.4 is the perfect tool for both professionals and hobbyists. The new special features such as focus lock, infinity click and hyperfocal scale set a new level of manual lens functionality. Focus lock enables to lock the focus ring at any time ensuring the chosen settings. Hyperfocal distance scale gives information about the accessible range for depth of field for a given aperture simply and intuitively. When the focusing ring is set in the “infinity” position, there is a noticeable “click” (infinity click), making it easier to find the value without looking.
Extraordinary optical performance
The Irix 15mm f/2.4 meets the most demanding requirements of modern cameras. Thanks to sophisticated optical construction and special neutrino coating, colour aberration, ghosting and flare effects have been reduced to the absolute minimum, so the lens is ready to meet the requirements of the 50+ megapixel sensors of the newest cameras.
The complex optical system consist of 15 elements in 11 groups. Three of the lens elements have a high refractive index and two others have been made from extra-low dispersion glass. The construction also contains two glass aspherical lenses that are responsible for extremely high image quality and improving image brightness at edges, while minimizing distortions and aberrations at the same time.
With a minimum focusing distance of 0.28 meters and 9 rounded shaped aperture blades, the lens stands for supremely smooth out-of-focus areas. Working with a narrow depth of field it allows the user to fully enjoy the bokeh effect.
Resistant to extreme conditions
Irix 15mm f/2.4 lenses are made with extreme precision, allowing them to be used in even the harshest weather conditions. Each lens is equipped with a weather sealed construction that protects the interior against dust and moisture. Thanks to inner seals they are also protected from accidental water splashes.
Prepare for more and create
Despite its short focal length and large aperture, the Irix 15mm f/2.4 is equipped with not only a front filter mount, but also has a rear gelatin filter slot. The design of the lens allows the use of 95 mm screw-in filters at the front in the petal-shape lens hood and gelatin filters at the back of the lens. This ensures unlimited possibilities for image creation.
Personalize your view
For the comfort of our customers Irix has created two versions of the Irix 15mm f/2.4 to meet their personality and individual taste.
Irix Blackstone: classic design meets maximum functionality, achieving the perfect match of innovative technology. The durable aluminium and magnesium body ensures foolproof protection of your lens, even in extreme conditions. Engraved fluorescent markings that reflect the light enable easy operation in all lighting conditions.
Irix Firefly: high quality mechanism in a handy design. Ergonomic focusing ring offers the freedom to capture the most ideal moment, whether it is big city architecture or wildlife scenery. The most lightweight lens in its class. Challenge accepted.
Ultimate precision
Each Irix 15mm f/2.4 lens leaving the factory has been properly calibrated. However, the focus calibration function provides the unique opportunity to adjust the focusing scale for a particular model of camera.
Used like new for $299
PR
Irix, the producer of the Cine series, currently has a set of cinematographic lenses in its portfolio, including an 11mm ultra wide-angle lens, a standard 45mm lens, and a 150mm macro telephoto lens. Today Irix premieres their fast, filter-ready wide-angle cine lens, the Irix Cine 15mm T2.6. This product will open unlimited possibilities for filmmakers and cinematographers alike.
New Lens, New Possibilities
The newest member of the family, the Irix Cine 15mm T2.6, is a fast, filter-ready ultra wide-angle lens, which makes it an extremely versatile piece of equipment that works in a multitude of lighting conditions.
The Irix Cine 15mm T2.6 optical system is made up of 15 elements arranged in 11 groups (including 3 HR lenses, 2 EDs, and 2 ASPs). Its precise construction ensures beautiful and vivid colors, image sharpness, and minimal distortion, despite the ultra-wide field of view. The high quality construction ensures low lens breathing, which is an extremely important feature in filmmaking.
Like all Irix Cine line lenses, it is designed for filming at a maximum resolution of 8K UHD, allowing for super-panorama shots (CinemaScope).
Irix Cine family
Ease of use and convenience is extremely important to us. Irix Cine lenses are ready for any film set. Very similar weights (as well as equal distances between rings) between Irix Cine lenses accelerate work on the set, without forcing changes of gimbals, rigs, tripods, etc. Irix also offers an innovative magnetic mounting system (MMS) for accessories, such as sun visors or lens covers.
Irix Cinematic Design
Irix lenses are used by both professional operators and amateurs alike. Irix Cine 15mm T2.6 has all the features and properties necessary to work on the set. By minimizing the phenomenon of diffraction, the lens' aperture (made of 9 rounded blades), provides a sharp image, regardless of the T value. The precise mechanics allow for the smooth adjustment of the T value from T2.6 to T22.
As with other Irix Cine lenses, the product has been equipped with an innovative adaptive ring that allows for ergonomic work both in manual sharpening and with follow-focus systems, thanks to which you can easily and quickly adjust your lens to your rig. The 180 degree focusing ring ensures precise alignment and a smooth focus pulling.
The lens front has been optimized to work with 95mm matte boxes. Toothed rings (Mod 0.8 M standard), ensure compatibility with most follow focus accessories and aperture adjustment available on the market.
Ready to work in any conditions!
With film lenses, it is extremely important that the equipment is suitable for work regardless of weather conditions. Irix Cine 15mm T2.6 has been sealed in four key places, so you can shoot in the desert and in full rain, meaning you can be sure that your equipment will remain safe.
Main features
- UltraHD 8K resolution
- 43.3 mm imaging field (Full Frame)
- Fast aperture T2.6
- 86mm front filter thread
- ultra wide angle imaging field
- minimal distortion
- compact and lightweight construction
- very low lens breathing
- sealed construction
- 95mm front diameter
- magnetic accessory mounting system (MMS)
- Removable lens hood
- compatible with follow focus systems
- engraved markings filled withUV-reactive paint
- adapter ring for faster work on the set
- possibility of mounting an additional lens support foot
Available mounts
Irix Cine 15mm T2.6 is available in Canon EF, Sony E, MFT, and PL mounts, each with either metric or imperial focus markings.
Pricing and availability
The lens will soon be available in a wide network of dealers available at: https://irixlens.com/dealers-l... and at https://storeeu.irixlens.com for 1195 Euro.
15mm T2.6 Irix Cine lens
Available at https://storeeu.irixlens.com/en/
Lens will be available in Nikon Z mount version soon. Cine version will be first but normal must follow.
Sony version coming
We plan to release lenses equipped with Sony E’s native mount in the near future. However, wo do not know when the first lens with E-mount will be ready for sale
Adobe Profile PR
Irix 11mm f/4.0 and Irix 15mm f/2.4 lenses: Now with official Adobe CC profile support
We would like to remind all current and future users of Irix lenses that as from June 19, the Adobe CC package is now officially supported for Irix 11mm f / 4.0 and Irix 15mm f / 2.4 lenses (from ACR 10.4) which allows automatic correction of distortion and chromatic aberration.
As one of the few manual lenses available on the market, Irix lenses are equipped with an electronic AE system which not only allows the user to control the aperture from the camera, but also to record information on exposure parameters in EXIF format, the effect of which is the possibility of continuous software development of our lenses.
We believe that photography should be a harmonious process, not a struggle.
Users of previous versions of Adobe software can still download the appropriate correction profiles from www.irixlens.com (http://en.irixlens.com/downloads).
These are really great lenses.
If you were thinking of buying an Irix 11mm & 15mm lens Blackstone version between 22 January and 10 February 2018, then there’s a great opportunity to do so!
We have a fantastic special offer at the end of this month which allows you to get hold of a Blackstone with a 15% reduction in price!
It means that you can get our luxurious version for a similar price to a Firefly lens.
Our PhotoPlus 2017 Interview
Firefly version review
MTF
https://www.focus-numerique.com/focale-fixe/tests/irix-15-mm-f-2-4-firefly-3465.html
TH Swiss company, listening to the requests and inquiries from their customers, officially announces the availability of the updated correction profiles for Irix 11mm and 15mm lenses to use with Adobe Photoshop Lightroom software.
The update concerns the improvement of the correction data for distortion and vignetting. Moreover, the way of displaying the profiles inside of Adobe program has changed. Earlier versions of the profiles required finding Irix lenses in camera's manufacturer tab, while in current version you can find both models of Irix lenses listed in dedicated tab called „Irix”. The profiles package for both lenses is now ready to download from the website irixlens.com on subpage: Updates →Downloads →Others.
Especially for Irix lenses users, TH Swiss prepared two video tutorials to explain how to install and use Irix profiles on Windows and Mac Computers. These video tutorials can be found on Irix YouTube channel: http://www.youtube.com/irixlens
Review
Centre sharpness is impressively high throughout the entire aperture range, with peak performance between f/4-f/11. Corner sharpness is also very good, again producing optimal sharpness at f/4-f/11. At f/16 sharpness is beginning to drop off a little due to diffraction, and is clearly evident at f/22.
http://www.photographyblog.com/reviews/irix_15mm_f2_4_review/sharpness_1/
Blackstone Lens Review
http://www.the-digital-picture.com/Reviews/Irix-15mm-f-2.4-Blackstone-Lens.aspx
Central sharpness is very good
https://www.ephotozine.com/article/irix-15mm-f-2-4-lens-review-30126
Good lens and optimistic reviews for now.
