F&V Z720S UltraColor Bi-color LED Ring Light
    Ready for Professional Cinema The Z720 was built with the professional cinematographer in mind. Industry standard mounting options will allow the Z720 to be used for productions both big and small.
    Unprecedented Color Accuracy
    The Z720 utilizes F&V's latest LED technology, the UltraColor LED. A precise coating technique and a meticulous review process ensures that UltraColor LED delivers accurate results every time. In fact, they guarantee it. Their UltraColor LED is rated at a TLCI 95+/-1.
    Battery Powered
    The Z720 is the perfect companion on the road. The unit can be powered by two, small, NP-F Li-ion batteries. You can even power the unit with one battery and the Z720 will precisely adjust the number of illuminated LEDs to 360.
    Precise Control LCD Display An illuminated LCD displays both intensity and CCT. Dial in your perfect settings everytime.
    **Unique & Gorgeous Catchlights, Independent Quadrant Control **
    The Z720's circuitry is divided into four quadrants. This gives each quadrant independent control over intensity and CCT. Create distinctive catchlights with the press of a button.
    Create and Save Your Scenes with Wi-Fi App
    The Z720 has a built in Wi-Fi module that allows you to control the light via your cell phone. Not only can you control the light with your phone, but also you can save the exact settings to your phone and recall it any time.
  • 2 Replies sorted by
  • F&V Z720S UltraColor (Bi color, daylight setting), measurement using Lisun, Russian Lab processing
    Focus on TM30 and CIE 224 and look for color distortion and Rf values.
    F&V Z720S UltraColor is good light with proper color temperature, light quality is quite good and suitable for videos.
    As you can see, TLCI claimed value matches measurement exactly.
    Color temperature
    CRI color quality
    CQS color quality
    TLCI 2012
    TM30 color quality
    TM30 details
    CIE 224 2017 (Rf = 90)
    687 x 418 - 29K
    800 x 403 - 53K
    637 x 460 - 52K
    642 x 421 - 50K
    785 x 495 - 64K
    800 x 326 - 45K
    464 x 458 - 31K
    800 x 266 - 63K
    753 x 562 - 56K
    507 x 504 - 45K
    797 x 373 - 39K
  • F&V Z720S UltraColor (Bi color, tungsten setting), measurement using Lisun, Russian Lab processing
    F&V Z720S UltraColor is good light with proper color temperature, light quality is good and suitable for videos.
    Color temperature
    CRI color quality
    CQS color quality
    TLCI 2012
    TM30 color quality
    TM30 details
    CIE 224 2017 (Rf = 93)
    800 x 447 - 35K
    800 x 405 - 51K
    646 x 493 - 54K
    663 x 407 - 48K
    747 x 591 - 63K
    781 x 485 - 65K
    800 x 330 - 45K
    458 x 460 - 31K
    800 x 268 - 69K
    789 x 374 - 39K
    497 x 500 - 41K
