Venus Optics, the camera lenses manufacturer who had previously launched a number of quality lenses with ‘World’s First’ specifications, is proud to unveil two premium lenses with extreme specifications and impressive performance, the Laowa 15mm f/2 FE Zero-D & the Laowa 7.5mm f/2 MFT.
Laowa 15mm f/2 FE is currently the World’s Fastest 15mm rectilinear lens for Full Frame cameras. It features a close-to-zero optical distortion, allowing photographers to take landscape or architecture shots with straight lines retained.
Dedicated to fulfill the need of photographers, Venus Optics have managed to add a 72mm filter thread onto the 15mm f/2 lens. Photographers can easily install standard screw-in filters without paying for an expensive yet bulky filter holder system.
Designed specially for the Sony Full Frame Mirrorless cameras, Venus Optics has successfully controlled the size and weight of the lens to the minimal. Weighing less than 1.1 pounds (500g) and 82mm in length, the portability and compactness of the Sony E- mount Mirrorless cameras can be maintained when used with the Laowa 15mm f/2 FE Lens.
Featuring the fastest f/2 aperture ever built with a 15mm lens, the new Full Frame E- mount lens is engineered for professionals to shoot impressive landscape, architecture and primary astro photos with great details. This is an every-day and must-buy lens that every Sony Full Frame Mirrorless camera user should have one in his bag.
MTF
Photokina photos
                  Preorder is available now
                  Small interview with lens designer
PR: We think your Laowa 15mm 2.0 Zero-D FE is a very interesting and versatile ultra wide angle lens with a unique focal length and maximum aperture combination, so we would like to know more about the process of designing this lens. It is Laowa’s first mirrorless design (together with the mFT 7.5mm 2.0), was the filter stack in front of the Sony sensor an issue or easily accounted for in the optical design?
Mr. Li: I’m very glad you are interested in the Laowa 15mm 2.0 Zero-D FE. As you know, the Sony mirrorless camera bodies are extraordinarily convenient and compact. But the same cannot be said of most existing wide-angle lenses, which are huge and heavy. It takes away from the convenience of the Sony bodies. And in shooting landscape, it’s not usually possible to use filters with any ease on these large wide angle lens. Another issue which typical wide angle lenses have is that they display levels of distortion which result in extra work in post-production, especially when shooting architecture. My goal was thus to produce a small lens, which could accept screw-on filters, and has very low native distortion.
Taking advantage of the design possibilities of the short flange focal distance of mirrorless cameras, I was able to restructure the entire design, getting rid of the conventional design concepts of wide angle lenses for DSLRs.
https://phillipreeve.net/blog/the-man-behind-the-lens-mr-li-laowa-15mm-2-0-zero-d-fe/
