Sony FS7 Mk II official topic
    • Electronic Variable ND (FS5)
    • 10 assignable buttons
    • New Lens Lock Ring (Lever Lock Type) No rotation of lens anymore to detach.
    • MPEG 2 Cache Recording
    • BT 2020 Color Space
    • New Arm Grip Position and Adjustments
    • New 1/4 Full HD LCD (960/540) and rod ergonomics improvements
    • $9999 price
    Product page https://pro.sony.com/bbsc/ssr/show-highend/resource.solutions.bbsccms-assets-show-highend-fs7ii.shtml
  • 21 Replies sorted by
  • Pictures
    800 x 552 - 50K
    800 x 354 - 37K
    800 x 377 - 37K
  • PR
    Sony Expands FS Series with New FS7 II Camcorder
    New Model Delivers Advanced Features for Documentary and Indie Production with Electronic Variable ND Filter, Lever LockType E-mount and Refined Mechanical Design
    Sony is expanding its FS Series Super 35mm professional family with the addition of the new FS7 II camcorder. The new model builds on the original FS7’s strengths by adding advanced features including Electronic Variable ND technology, a lever lock type E-mount, and a new mechanical design for faster and easier set-up. The new FS7 II camcorder also supports Sony’s αMount System, which includes more than 70 lenses.
    Since its introduction in 2014, the FS7 has become one of the most widely used cameras in a range of production applications, and the original FS7 model remains in the Sony line-up. The new FS7 II now gives creative professionals a broader range of creative tools, with new features all based on end user feedback.
    The new FS7 II camcorder is designed for long-form shooting and production applications, especially documentaries and independent filmmaking. Sony is also introducing an FS7 II kit model which includes a new E-mount, Super 35mm lens, model SELP18110G, covering Super35mm and APSC sensors.
    “The FS7 II features state of the art, Sony variable ND technology and a robust locking E-Mount,” said Juan Martinez, senior product manager, professional digital imaging, Sony Electronics. “Extensive enhancements to the VF support system enables super-fast and secure viewfinder repositioning, while retaining the Zen-like simplicity, flexibility and comfort of the FS7’s ‘multi-award winning’ industrial design.”
    Electronic Variable ND Technology
    The camcorder’s Electronic Variable ND Filter system, combined with its large sensor, delivers greater exposure control, with the option of preset or variable operation modes.Variable ND mode (seamless ND attenuation within the camera’s 2~7 stop range) allows the user to vary the density of the ND filter during shooting and to transition seamlessly between steps.
    The camera’s expanded ND operations also enables fine exposure adjustment by relegating iris to set depth of field, prevents soft focus caused by diffraction, and prevents color shift caused by stacking multiple external ND filters.
    Preset mode lets users assign three ND settings to the filter turret, useful in selecting the most appropriate filtration range for changing light conditions. Auto ND mode is also availableallowing exposure to stay at a fixed level while adjusting the depth of field with iris control.
    E-mount (Lever Lock type) for professional shooting
    The FS7 II’s new E-mount (lever lock type) gives users theability to change lenses by rotating the locking collar rather than the lens itself, which means that in most cases lens support rigs don’t need to be removed, saves time during a production.
    Mechanical Design Enhancements
    Like its counterparts in the FS Series family – the FS7 and FS5 models – the new FS7 II features several design and ergonomic updates for comfortable and functional use in the field.
    The FS7 II’s “tool-less” mechanical design lets users make on-the-fly changes to the camera’s set-up and operation. For example, no tools are required to adjust the Smart Grip or viewfinder positions.
    The viewfinder eyepiece provides a third stabilizing contact point when shooting handheld. Durable square section rods and lever-clamps on the LCD and camera body provide simple and precise front-to-back VF adjustment while retaining level positioning.
    New Sony 18-110mm Sony G lens
    Sony is also introducing an FS7 II kit model including a new E-mount, Super 35mm lens. The new lens, model SELP18110G, covers Super35mm and APSC sensors. Compact and lightweight — 2.4 lbs (1.1Kg) — with an 18 to 110 focal range (6x zoom) it uses a new fully mechanical/servo zoom switchable system, capable of snap zooms and entirely devoid of lag. The focal range is optimized for Super 35 and APS-C sensors.
    The lens is compatible with Sony α Mount System cameras, including the α7 series interchangeable-lens cameras and professional Super 35mm 4K camcorders like Sony’s FS7 or FS5. Although perfectly suited for still image taking, filmmakers will fully appreciate the lens’ extended creative capabilities for shooting motion images.
    The lens benefits from Sony’s Smooth Motion Optics (SMO) design, which is developed to optimize performance during motion image capture. This lens design eliminates undesirable characteristics and artifacts that do not affect still image capture, but can severely limit a lens’ usefulness for motion shooting, such as:
    • Ramping: F stop gradually diminishes when zooming tight.
    • Not holding focus while zooming.
    • Breathing (angle of view variation while focusing).
    • Optical axis shift (image moves in the frame while zooming).
    XQD Cards
    The FS7 II supports the XQD memory card format, designed for capturing and transferring high-bandwidth, high resolution files. Sony is also introducing a new XQD card, QD-G256E — with an industry first 256 GB capacity – which enables a recording time of approximately 45 minutes at 4K 60P and 3.5 hours at 2K 30P. Combined with a read speed of up to 440MB/s and write speed of up to 400MB/s, users can shoot for longer without needing to change media cards.
    The FS7 II is planned to be available in January 2017 with pricing to be announced.
  • German dealers offer pre-oders at 11.200€ net / 13.328€ incl 19% German VAT This is outrageous compared to 9.999USD
    And the price is even with the C300II now. The FS7 was a big success for Sony but I doubt that sales rates will go on like that at least in Europe. For FS7 owners (like me) there is no technical or visual feature a client will pay extra for. There is no reason to pay estimated 5-6K difference when switching from FS7 to MII. And as a new buyer it will be a not so clear decision between C300II and FS7II at the same price. Or even go for a FS7 with 7.059€ net
  • B&H is accepting pre-orders at $10000 USD: https://www.bhphotovideo.com/c/product/1295217-REG/sony_pxw_fs7_ii_xdcam_super.html
    The main recording quality improvement over the original FS7 seems to be the ability to record in the larger Rec 2020 color space.
    They really should have added direct support for RAW output over SDI (like the FS5 has), rather than requiring the extension unit. That might have made it a more enticing upgrade.
  • About Rec 2020 it is useful - http://www.personal-view.com/talks/discussion/15946/note-to-rec-2020-proponents/p1
    While it can record in this space - no way it can reach primaries except if using fake software processing.
  • Interesting, I wonder what percentage of the Rec 2020 color space the sensor is actually capable of capturing?
    At least for displays, some of the manufacturers have started reporting what percentage of P3 or Rec 2020 color spaces they are capable of reproducing. And there has been some testing done for TVs such as this: http://www.rtings.com/tv/tests/picture-quality/wide-color-gamut-rec-709-dci-p3-rec-2020
    But for cameras and the capture side of things, this kind of information seems harder to come by.
    Most of the camera manufacturer's proprietary wide color gamuts (Sony S-Gamut, Panasonic V-Gamut, and Canon Cinema Gamut) are already larger than Rec 2020. But that may not mean much if the cameras are only capable of capturing a fraction of these larger color spaces.
  • Interviews
  • Brief look at camera
  • First look
  • French Cuisine and Behind the Scenes
  • Brief functions video
  • ND filter
  • Our interview at NAB 2017
  • Development team interview
    A key part of FS7’s appeal is Sony’s E-mount which helped keep the camera compact and lightweight, while providing the widest possible range of compatible lenses…
    However, as FS7 users were using the camera for ever more ambitious projects, there was a clear demand to strengthen the lens mount to support heavier lenses. This would prove to be one of the FS7 II’s most challenging engineering tasks.
    Adding both strength and rigidity would be difficult enough, but mount design head Miyao had to do this without changing the camcorder’s dimensions.
    https://www.sony.co.uk/pro/article/broadcast-products-camcorder-fs7m2-team-interview
