Well, I can sell you idea. :-)
Get http://www.personal-view.com/talks/discussion/17148/jtz-dp30-rig-and-cage-for-gh5-gh4-gh3#Item_8
Idea is exactly to make camera bigger for event coverage and for shoulder cam stuff. Plus you have controls on top handle and right handle.
I really need someone to "sell" me the idea of camera cages. I've never owned one, and struggle to understand why I would want to make a small camera bigger.
Now- don't misunderstand me: I think camera "rigs" are great, as this adds stability for shooting. Just a cage by itself always seemed to me large. Maybe I need to get one and see how it fits into my workflow?
Maybe if I used a HDMI recorder a cage would make more sense.
Then again I have been working hard on my GAS problem.
UPDATE: Watched Zacuto video in full. I think this video just sold it to me! :-)
I generally use one specific ND size and different ring adapters to apply the filter to any kind of lens.
I mean ring adapters like this: http://www.eflens.com/images/articles/adapter-rings.jpg
@Odur you use a dedicated filter per lens? Or simply use one ND size with adapters? If so which do you have? I really have to invest in more ND's. Mainly use Matte box but want to move to screw on.
@Vitaliy_Kiselev :-( Must be lots of testing of bushes. (Reminds me of PTool days!) Only this time Panasonic is doing the hacking. :-)
Thank you. I've used ND8 and ND16 filters plus a polarized filter.
From my sources got small leaks.
Panasonic has some issues with promised firmware update.
Seems to be issues with buffers/SD controllers on such high bitrates and few errors in encoders that need to be bypassed.
For now management still optimistic and hope to push developers more and try to make something till September, or at least October.  But who knows, some of promised features can be adjusted.
@Odur lots of outside filming, what ND's did you choose to use? Lovely video BTW! And how special is that event!
Thanks, it took me some time to work with these flat images, but at the end I like the results. I'm sorry that the streaming is causing heavy compression artifacts in the more complex scenes (like the one used for the video cover), maybe streaming at 4k resolution could reduce the artifacts. Looking at the original, even in the most stressful situations there's no match for the online version.
If False Color is can be apply with Lut method, Panasonic should really put this function in the camera.
True, however its also possible for us to choose from any LUT that applies false colour. Thus we can get in future (or if someone makes it) false colour LUT's with many different usages.
What would be cool is a function button assigned to swapping LUT's, so we can easily move from one out to the other. (maybe this is already available?)
I would also like to see LUT playback of stored VLog-L footage, currently its only Log, which makes review problematic without ingesting onto laptop etc.
Review
The GH5 is a video camera that happens to take still photos. The ISO performance for video has been dramatically improved, with noticeable and marked advancement in low light performance. Even at the highest ISO the GH5 can attain in video mode, ISO 12,800, footage looks "passable," whereas the GH4's maximum ISO of 6400 was best avoided with video. Apples to apples at ISO 6400, the GH5 blows its predecessor out of the water. There is also no longer an additional crop factor even when shooting 4K video, with the entire width of the sensor being utilized. This is a boon to wide-angle shooters.
http://www.imaging-resource.com/PRODS/panasonic-gh5/panasonic-gh5A.HTM
@AKED true UHSII are faster, but it's a pity there is no real difference between 180MB/s and 280MB/s.
I wonder if the USHII areas of the GH5 firmware are not switched on yet? (or not optimised)
I was trying to say 'areas' of the firmware that were not optimised. If there 'are' areas that are not optimised.
That's why I was thinking that there may be further optimisation possible? I suppose however that it does come down to how fast Panasonic have clocked the SDCard Slots, IIRC UHSII due to the greater amount of pins is able to transfer more information with same UHSI clocking.
Also if Panasonic were to clock the SDCard higher it would most probably cause thermal issues (if its even capable of being clocked higher that is). I know many SOC devices with SDCard's have chips that can be clocked higher - such as the RPi for example. (I know the GH5 isn't an RPi- just saying).
@alcomposer Well, the UHS-II are twice as fast as the UHS-I cards. If you look what Transcend writes on the cards regarding write speed: UHS-I: 90 BM/s and UHS-II: 180 MB/s, this is 100 % conform with my experiences. In so far are the USH-II cards definitively working in the GH5.
Just the difference between the UHS-II card from Transcend and the UHS-II card from Sandisk are, at least in my tests, not existing. Maybe they would show in other tests. In mine, they both cards were equally fast.
Hey @AKED thanks for the info re: USHI v's II.
I wonder if the USHII areas of the GH5 firmware are not switched on yet? (or not optimised). I suppose we will find out after the 1.2 firmware update.
