4K Low mbit sample, LG_4K_View-the-Feeling (2160p@29.970fps ~25Mbps)
4K High mbit, high fps - Crowd_run 4K@50fps -300Mbps
4K Very high mbit, 60fps, 8bit - Netflix_TunnelFlag_4096x2160_60fps_x265_8bit_700Mbit
8K MBC UHD Music Core GFriend - Rough (4in1) 8k@60fps-80Mbps
From https://forum.doom9.org/showthread.php?p=1799099#post1799099
If camera HEVC stream matches standard 4K HEVC native files (both 8 and 10bit) must be editable in properly made NLE on latest GTX cards or even CPU.
Yet most popular NLEs internal pipeline design is very old and so horrible...
It is not about HEVC decoding in general, it is about GPU support.
As far as I know, if HEVC is decoded by hardwire in Vegas it is only if you have suitable CPU (QuickSync).
does quicksync only work with igpu? or if I put in an nvidia 1080ti (or any other nvidia gpu) do I lose these cpu decoding features?
Also, what does that mean with i9? will i9 that has no igpu has some sort of decoding features? or "quicksync"
really i mainly care about premiere and media composer usage. I think there are 2 things to think about in this topic... Render speeds, and playback speeds. Obviously ryzen renders pretty quickly, but playback uses different tech no?
QuickSync is part of Intel GPU. If it works while 1080ti will be making output depends on NLE and settings.
i9 is actually remarked Xeon line CPUs without GPu at all, so no QuickSync.
They are kind of useless, whole lineup is temporary patch until 6-8 core consumer CPUs.
With Apples use of HEIF on iOS 11 we will most probably get system wide HEVC support sometime soon in macOS... I'm sure MS will update as well.
They already included system wide HEVC support in High Sierra, if you missed it.
I missed it. Only had my android device which "does not support live streaming" lol
Ironically "live streaming" works on MS.
Guys who made such streaming are idiots, as such decision cost them tens of billions of dollars.
NVIDIA Video Codec SDK 8.0 release. Highlights of the release include:
- 10/12-bit decoding support with HEVC/VP9, enabling end-to-end HDR transcoding Improved quality via weighted prediction
In LAV filters already added - https://files.1f0.de/lavf/LAVFilters-0.70.exe
GPU in AMD Ryzen based mobile CPUs have HEVC decoder
In other words - look at notebooks with 1xxx Nvidia GPUs.
