Hi guys. Finally I could test the Keyeasyfocus in an real job and it´s works fine with my Ronin-M configuration (Blackmagic Microcinema + Speedbooster BMPCC + Sigma 18-35mm 1.8)...but it is still a steal. I had a problem when the AAA batteries ran out and I didn´t figure out in that moment because the FF seemed to start correctly, so I sent an email to Kirill Domnin (k-devices account manager) but he never answered me...and the kdevices web is offline... I did a small research and I found that the motor used in this devices costs 7€! is this: https://hobbyking.com/en_us/aerostartm-as-559mg-high-torque-mg-servo-9-35kg-0-13sec-55-6g.html?___store=en_us
Issue with all cheap electric FF is bad noisy motors and sometimes even bad fixing.
CAME TV is around cheapest you can get with reasonable quality.
I was just about to recommend the same one from a US ebay link:http://www.ebay.com/itm/Mini-200M-Single-Channel-Wireless-Follow-Focus-Gimbal-Controller-Limit/132026840591?_trksid=p2047675.c100012.m1985&_trkparms=aid%3D777003%26algo%3DDISCL.MBE%26ao%3D2%26asc%3D40130%26meid%3Db85f9e1b3d2c4292977bf6405f7b5a0b%26pid%3D100012%26rk%3D3%26rkt%3D11%26sd%3D281997997651
I think it would be superior to the Keyeasyfocus, if the wireless works as well a cabled version would.
Cheap and wireless might not be a good combination.
Let us know how it all turns out!
Finally I have purchased the Keyeasyfocus. The seller told me that I can return it if I´m not satisfied with its quality, so I think that if it works right I will be happy even though I know it is expensive...I am very bad with DIY things, and I like very much the simplicity of this electric follow focus, so for me could be a good gadget.
I am still thinking on purchasing a cheap wireless unit like the one that @bannedindv has shown before, or other models even cheaper like this one: http://www.ebay.es/itm/132026840591?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT ...but I wondering how can I mount them on the Ronin-M if I want to operate focus by myself...any ideas? Thank you.
@bannendindv that it´s really a cheap one, I´m gonna do a research to find more information about it, thank you so much.
Thank you @Cfreak , as you perfectly said, 100-150€ would be fair enough in my opinion...but I´m still thinking on pulling the trigger, as I think it´s a good solution to control focus by myself when I´m working in videoclips without any AC , and maybe it can also be used by an AC close to the gimbal as the cable looks like longer enough to do that.
I contacted the seller to ask if it could be returned in case of not being satisfied with the quality of the product, and he answered me with an offer of 290$, which makes me think that he does not accept returns...
As for the noise, I sent him a link to Tom Antos's review of the Wondland wireless ff and he replied that the noise it´s similar. I told him that ideally he would send me a video made by himself to check the actual noise of his product, but he did not want to, claiming that the noise can be altered in the edition (in reference to the Tom Antos video) to make it quieter or louder. But this answer, added to the non-response about the return policy makes me think that I should not buy the product ...
Even cheaper than this exists with single channel.
Might as well have dual so you have a spare motor.
@alvaro for $100-150 it'd be worth it. $300 is a little steep, perhaps. It is a good idea and looks well thought out, except: it's probably not silent, has a ;limited range of 2 settings" 110 degrees and 160 degrees. You would have to set one side to your inf focus and then let that range become as far to near focus as it will travel. Also, if the range of travel is farther than the lens has, it will probably grind and push the motor away/off the lens. Also you'd like to have a reverse direction switch for the times you are using Nikkors or have to mount the motor flipped around another way.
You could probably build the same thing from servo city for less. I did once see a youtube video if a guy who had done something with 2 motors for his anamorphoic set up to maintain focus, with parts from Servo City and it was a lot more high tech than this.
I would love to see somebody come up with an affordable hardwired solution, or this company to bring out a v2 with these suggestions. I don't have the skills myself.
Hello. Has anyone tried this electric follow focus? I want a cheap but reliable solution to control focus using a gimbal Ronin M. When I need, I can rent the Dji wireless Ff, but I would like to have something for small or no-budget projects, and personal use. Thanks. http://www.kdevices.com/keyeasyfocus-eng.html
Opteka FFR-900 Motorized Remote Follow Focus & Zoom Controller with Shoulder Support Rig for $249
http://www.amazon.com/Opteka-FFR-900-Motorized-Controller-Camcorders/dp/B00AQNRXDS
MovCam
DJI wireless follow focus. Remote can be used with the X5 without the motor also.
CAME reduced FF price even further (want to save slightly more - contact us via PM) http://www.came-tv.com/cametv-wireless-follow-focus-controller-motor-inside-receiver-p-660.html
I have an RTMotion. It's phenomenal. Three axis controller / receiver, aux included in the base model. Short of a $30k Preston, it's the best deal if you'll ever have more than one axis and not a bad deal for a single axis (just about the same price as a BFD). The reason I went with it over Bartech was the size and weight of the on-camera motor and receiver. The RTMotion is TINY and very very powerful.
to me, lenzhound seems like the best bang for buck option.
CAME TV follow focus
Cheap one like on first post ($189):
Silencer guys reduced prices
https://www.kickstarter.com/projects/24shots/silencer-follow-focus-system
