Specifications:
Kenko Tokina Co., Ltd. is pleased to announce the new FíRIN 20mm F2 FE MF. FíRIN 20mm F2 FE MF is the first in Tokina product line compact form-factor super wide ultra fast F2 aperture manual prime lens compatible with Full-Frame E-Mount mirrorless cameras.
FíRIN 20mm F2 FE MF belongs to a newly launched “FíRIN” series of Tokina lenses for mirrorless cameras (or ILCs – Interchangeable Lens Compacts) marking a new epoch in Tokina history. FíRIN is a variation of Fírinne – the old Irish word for “truth”. It means “that what is real” and signifies “being true to someone or something”. It represents a promise from Tokina to photographers to help them capture the truth in their images with this revolutionary new lens.
Main Features
Perfect match to SONY A7 series body in terms of design, high-precision Japanese made parts and form factor.
Being compact and light-weight, FíRIN 20mm F2 FE MF performs excellent optical abilities due to perfectly placed two all-glass precision molded aspherical elements with 3 Super-Low Dispersion (SD) glass lens elements that are greatly reducing aberrations and yielding higher resolution and contrast. All lens elements are carefully multi-coated that helps to reduce reflections and flares to an absolute minimum.
The FíRIN 20mm F2 FE MF has an ability to encode and transmit aperture, distance and optical data to the camera body making this lens fully suitable in terms of using MF assist function, 5 axis image stabilization and view finder electronic distance scale. Lens CPU with optical correction data noticeably contributing to final image processing inside the camera.
Design devoted to manual shooting and cinema enthusiasts includes a wide manual focus ring, aperture ring and depth of field index bar.
De-Click Aperture function makes this lens suitable for cinema/video shooting.
Soft and expensive, like a good couch.
Review
Hungry cat without food due to LAS
http://www.mobile01.com/newsdetail/20497/e-mount-tokina-firin-20mm-f2-fe-mf
The lens will be available January 27, japanese retail price is ¥108,000. Us one - $799
Shipping is expected only in Q1 2017, with widespread availability closer to April.
You must also be ready for premium price.
There's more than one Pancake! The Panny pancake, the one, the true, the real pancake, is smaller and faster and does not need much software correction not that it matters. It will be interesting to see if the new Kenko will deliver. I'm not a fan of big fat lenses but if the IQ is there, who knows. And now, back to testing the Olly 75mm. Yowza.
@IronFilm I think you've got it backwards. Both of these 20mm lenses are for E mount and the 20mm Sony pancake it is a stop slower.
The panasonic is MFT. All MFT lenses are a lot smaller for the same focal length/speed than their larger sensor counterparts (APS-C and FF).
Plus, the panasonic pancakes are not optically solid on their own. They require quite a bit of in camera correction. An all manual lens like this must stand on its own optically.
@IronFilm the Panasonic is faster, the 14 is slower. Maybe the T number is better, I did not see it....
A bit bigger than the pancake 20mm, that's for sure.
That is because it is for FE, not APS-C, and it is a stop faster.
