70-200mm review
FE 70-200mm f/2.8 GM is really sharp lens. From wide open lens maintains very high sharpness in the central 2/3 of the image, and very good sharpness at the edges. It is same both at the wide end and the telephoto end, which is great. Stopping down a touch brings the edges to excellent territory, with even quite sharp corners. It’s definitely a lens that you can simply choose the aperture based on depth of field, and not worry about sharpness.
http://admiringlight.com/blog/review-sony-fe-70-200mm-f2-8-gm/
24-70mm GM in Germany dropped to 2109 EUR
Used starts at 1957 EUR
https://www.amazon.de/gp/offer-listing/B01BUAVMQY/ref=dp_olp_all_mbc?ie=UTF8&condition=all
70-200mm GM review
http://photoreview.com.au/reviews/lenses/other-ilc/sony-fe-70-200mm-f-2.8-gm-oss-sel70200gm-lens
70-200mm review
70mm
200mm
Sample
https://www.focus-numerique.com/zoom/tests/sony-fe-70-200-mm-f-2-8-gm-oss-3063.html
Sony FE 70-200mm F2.8 review
70mm
200mm
Sample
https://www.ephotozine.com/article/sony-fe-70-200mm-f-2-8-g-master-oss-review-30557
Sony FE 70-200mm f/2.8 GM OSS lens measurement by DXOMark
The advent of super high-resolution camera sensors demands new lenses with phenomenal resolving power to maximize their potential. The range of FE-mount Sony G Master, or GM, lenses fits the bill for full-frame Sony a7 shooters, bringing with them first-class optical construction and a large number of elements to squeeze as much out of the sensor as possible.
https://www.dxomark.com/Reviews/Sony-FE-70-200mm-f-2.8-GM-OSS-lens-review
Sony FE 70-200mm f/4G review
70mm
200mm
Sample
https://www.ephotozine.com/article/sony-fe-70-200mm-f-4-g-oss-review-30468
24-70mm review
Sony's marketing made some pretty aggressive announcements at the time of the announcement of their new GM lineup. The Sony FE 24-70mm f/2.8 GM is the first GM lens that we tested here and while we are impressed by the quality, it didn't really blow off our socks either.
70-200mm measurements
More 85mm GM Samples
http://crepesandcameras.blogspot.nl/2016/12/sony-85mm-f14-g-master-lens-review.html
70-200mm comparison with other long lenses
Shot on 24-70mm G-master and A6300
Sony G Master 24-70mm F2.8
http://riflessifotografici.com/index.php/english/517-sony-g-master-24-70-f-2-8-e-85-f-1-5
