I had used the mods by jollyrogerxp many years ago to limit gain and to change NTSC to PAL models. Turns out that the HV20.com site is no longer in existence.
I'd like to upload the hack files for archival purposes.
Links :-
Canon Firmware Decryption Tools
https://github.com/protyposis/CanonCamcorderFirmwareTools
https://protyposis.net/blog/decrypting-canon-camcorder-firmware-updates/#comment-128
From Time Machine :-)
http://web.archive.org/web/20100727174315/http://hv20.com/showthread.php?t=20098
Flip hack firmware tested successfully, available here!
PLEASE NOTE: even if you have region-switched your camera with the other firmware hack, you must use the proper version for your camera. The NTSC version is for original NTSC ('Vixia' & 'iVIS') HV30s, the PAL version is for PAL ('Legria') cams.
LCD Flip Firmware — NTSC Cameras Download link: http://hv20.info/yopu/HV30_Modified_Firmware_v1_1b.zip
LCD Flip Firmware — PAL Cameras Download link: http://hv20.info/yopu/HV30_Modified_..._v1_1b_PAL.zip
Region Change firmware hack is here!
Our fearless leader has agreed to host the 'patched' firmware here at HV20.com. It's here! Follow this link to download:
Region Change Firmware Download link: http://hv20.info/yopu/HV30_Region_Hack_v1_0.zip
WARNINGS: For the moment, these firmware modifications are only known to work on the HV30. Attempting to install either on any other model might well brick your cam. These are non-factory-authorized, use-at-your-own risk, version 1.0 firmware modifications. Installing either may void your warranty. Be sure to carefully read and follow jollyrogerxp's instructions. You will also need to download the "official" HV30 firmware update from Canon.
These hacks may also work with the HV20, however there is a significant risk they may brick the camera. A partially-broken HV20 has been purchased from the hack fund for Jolly to experiment with.
BELOW IS THE OLD STATUS FROM FEB 2010:
Check the main thread, and 5.1) WIKI: http://chdk.wikia.com/wiki/HF10/100_Firmware_Analysis 5.2) WIKI: http://chdk.wikia.com/wiki/HV20 5.3) WIKI: http://chdk.wikia.com/wiki/HV30_Firmware_Analysis
Got the files from 4shared - so check them to see if genuine..
HV20_HV30_Modified_Firmware_v2_0.zip
https://dl.dropboxusercontent.com/u/9906333/HV20_HV30_Modified_Firmware_v2_0.zip
Perhaps Vitaliy could host the file on this site and update the wiki as there is no home for this hack anymore. For the record, the HF10 firmware was similar and was decrypted before work had stopped. These cameras provide a pristine 8-bit 4:2:2 signal on a full HDMI port and work great as studio cameras recording to HDMI recorders.
What files are necessary to upload to PV?
and the other files are on github.
Hi Can someone sent me the files to convert Canon hv30 ntsc to pal ?
