I tried Color Finesse. It didn't have the tools I need.
@balazer Sounds like more like a job for After Effects than Premiere Pro. AE can load .cube LUT's into 32-bit linear ProPhoto color space, and the Color Finesse plugin bundled with AE provides those kind of color tools.
Thanks, @tetakpatak. Can Magix Video Pro X7 load LUTs? How about the current version? That's one pre-requisite. But there's more too it than just that because it also needs to have the right kinds of color tools for dealing with a log space, namely, global offset, individual R, G, and B channel offsets with fine granularity, and contrast as a straight-line slope with the right pivot. I wish I could just publish a set of LUTs or a plugin that would work everywhere, but each video app has its own quirks for how it reads LUTs and how it reads video files and maps levels, and different built-in color tools. And so I had to compensate for all of that and make different LUTs for each app.
Amazing, truly amazing work @balazer! I must have eaten s much work and time to develop it. Pity that I can't use it with Magix ProX7
@uliman, thanks for the feedback on J-Log1. Premiere Pro is something I may find a way to support in the future. Currently it doesn't have the color tools necessary for working in this type of log space.
Hi balazer, any chance for a version which works with adobe premiere pro cc? Works wonderful in FCP Pro x with JVC J-Log. Much headroom, smooth highlights. Thank you for your work..
@balazer I used some old footage from the GH4 and D750. On the GH4 I used the Cine D footage and the on D750 I used some footage that I shot with Neutral profile. Per your instructions it was really easy to get a to good starting point along with balancing out the image, super quick actually... :-) On a side note I sold the GH4 and am replacing it with the Fuji XT-2 so I am interested to see how that works out with your luts and grading in general.
Thanks, @majoraxis. Yes, when you shoot with less than perfect settings in the camera, it won't be as damaging as it would be without Logarist. That's a good way to put it. Logarist doesn't give you unlimited latitude for mistakes, however. You'll still get the best results when the settings in the camera are right. The way I operate is to try to get the exposure and white balance fairly close in the camera. It doesn't have to be perfect. That frees me up to worry about camera motion, framing, and motion. Then I use Logarist to get the colors the last bit of the way to where I want them.
You can get the same results with Sony Cine1 or Cine2. The only real difference is how things will show in the histogram and with zebras while you're shooting.
@Azo, I'm glad to hear it. Which camera did you use?
I tried it out in Final Cut Pro X and it works out great. Really quick and easy to make adjustments to the image. @balazer Thank you for all of your work and providing this to us for free... Very much appreciated...
If only I knew how to use resolve.
Bravo, thanks for making this, I've always wondered no one made a lightroom style plugin for NLEs that actually gave good results.
Coming from more of a photo background, CC and grading has always been painful for me in video.
Love that you made this!
@ balazer: Thank you for this valuable tools set, instruction video, 3D LUTs and informative website!
After setting my camera settings to the recommended settings from your website, I graded a clip with and without your LUTs and it definitely looks better and was quicker and easier to get a look I was happy with. What I like best about it is, that extreme settings are simply extreme and not as damaging as they would be if I was applying them without your LUTs.
This is what I have been looking for my A7RII footage along with the Still color setting instead of Pro - the colors are nicer as well.
If you have a Sony A7x, A6xxx, it's worth trying the camera settings listed on the website as well as the 3D LUTs when color correcting.
Any advice one whether there is an advantage to using Cine1 to Cine2 for the gamma?
The major bullet points here are exactly what Balazar points out: global adjustment of exposure compensation, white balance, and contrast. As with JPEG versus RAW still photography, these properties are burned into H.264 video recordings, regardless of whether you shoot in log or Rec 709 profiles. Normally when grading H.264 footage, you're working in a Rec 709 color space, either natively or converted from a log profile into Rec 709 by a calibrated 3D LUT. In that situation, you must work with the exposure, white balance, and gamma profile that were selected at the time the footage was shot.
Converting H.264 footage into a standardized log color space (in this case a version of ProPhoto RGB), allows exposure, white balance, and gamma curve to be adjusted in post-production, similar to how Adobe Lightroom uses ACR to manipulate these properties in RAW photographs. The color science behind this is well-defined and valid to the level of color fidelity recorded in the original footage.
Regardless of the working color space, what's open to personal opinion is how to best manipulate the footage with post-production tools. As with most photograhic software, Adobe Lightroom treats exposure, white balance, and gamma globally across the histogram range, and provides its own custom controls for separately adjusting highlight, midrange, and shadow properties. For example, the effects of Adobe's "contrast" control vary depending on which process version you select in ACR. It's a subjective interpretation rather than a calibrated adjustment.
With video color grading tools, it's more common to provide separate sets of calibrated adjustment controls for highlight, midrange, and shadow regions, as well as a master set of controls for the entire histogram range. This partially compensates for the absence of a global white balance adjustment, which cannot properly be performed in Rec 709 color space. Balazar's log color space conversion fills in that gap, allowing you to alter exposure, white balance, and contrast within the host application.
What's notably missing is support for Adobe Premiere Pro and After Effects, which I'd imagine is not an oversight, but due to more substantial issues?
Thank you, looks interesting. Your video is awesome, so clear. That's how it's done.
Hi, @Ralph_B.
It's a way to get better looking images with less effort. Existing color spaces are optimized for delivery or capture, not for color correction. You can do color correction in those spaces, but it's more work than it should be and it's difficult to get a perfect result. Exposure compensation, for example, would require a very precisely shaped curve. White balance correction would require separate adjustments to shadows, midtones, and highlights. Some people are used to working that way, but I always found those methods troublesome, so I made something better.
If you're the kind of shooter who always manages to get perfect images straight out of the camera, you won't benefit from this. But for the styles of shooting that I do in the field, often in sunlight and varying lighting conditions, almost everything I shoot benefits from some color tweaks.
Hi balazer,
Obviously a lot of work went into this. Can you explain why you did it? What does it give you that current tools do not?
