Here is a comparison video, comparing the internal 8bit 4:2:0 to external 8bit 4:2:2 recorded at a much higher bitrate on the Atomos Shogun. Heavily graded from Slog2/Sgamut. Lots of color.
You can download the original rendered in 10bit 4:2:2 at a high bitrate. If you see a difference, go for it.
Thanks, markr041! Seeing that... I think only trained eyes can spot the difference. But i believe that record externally might be very useful if you plan grade your images...
@samuelcabral Those videos were heavily graded. The originals were flat colorless log files.
