PR
Canon has unveiled the EOS C300 Mark II, a new 4K Digital Cinema Camera allowing filmmakers and broadcast producers to realise their creative vision in stunning cinematic detail.
Building on the unprecedented success of the acclaimed EOS C300, the more rugged EOS C300 Mark II features an advanced imaging engine with Dual DIGIC DV5 processors, new professional codecs and outstanding dynamic range, making it the most capable, flexible and accessible Cinema EOS video camera to date.
SUPREME 4K IMAGE QUALITY AND VERSATILITY
With the ability to record 10-bit 4:2:2 files internally at up to 410Mbps in 4K, or 10/12-bit 4:4:4 files in 2K/Full HD, with up to 15 stops of dynamic range, the EOS C300 Mark II provides footage suitable for extensive post-production work, producing crisper images across the full colour spectrum with reduced “colour bleed”. The camera offers professional filmmakers and broadcasters alike the very best image quality, recording 4K in both broadcast (3840 x 2160) and DCI cinematic (4096 x 2160) resolutions.
The EOS C300 Mark II can record high bitrate 4K files internally to dual CFast 2.0™* media, while simultaneously recording 4K RAW files to an external recorder, offering the flexibility and universal appeal for production at the highest quality available today. Additionally, the ability to record 2K/Full HD Proxy files to an internal SD card, at the same time, further streamlines the production workflow process.
The EOS C300 Mark II features an all-new Super35mm CMOS sensor, designed by Canon, with a stunning ISO range of up to ISO 102,400. The new Canon-designed Super 35mm CMOS sensor and an increased ISO range up to ISO 102,400 deliver exceptional low light performance, allowing operators to capture low-noise footage across a variety of challenging environments without compromising on image quality.
To meet the requirements of a diverse range of shooting applications and lighting situations, the EOS C300 Mark II offers both full manual control, ideal for cinematic environments, as well as a variety of automatic modes. These include enhanced Dual Pixel CMOS AF (now covering approximately 80% vertical x 80% horizontal of the image display), Auto White Balance and Face Detection AF, all of which make it easier than ever before for independent news gatherers and documentary filmmakers to shoot on the go without having to worry about settings.
INSTANT INTEGRATION INTO PROFESSIONAL WORKFLOWS
Canon’s new range of XF-AVC H.264 codecs, designed to be compatible with industry standard Non-Linear Edit systems, makes integrating both 4K and 2K/Full HD footage into workflows effortless, while maintaining the highest image quality. The range features XF-AVC intra for 4K, and XF-AVC Long GOP and Proxy options for 2K/Full HD recording, both of which utilise H.264 codec, offering post production flexibility and ease of use. Filmmakers can select the resolution and codec type that best suits their production, with the EOS C300 Mark II capable of shooting at up to 30P in 4K or up to 120P in 2K/Full HD.
The EOS C300 Mark II offers support for a wide range of colour space options, including BT.2020, the Canon Cinema Gamut and DCI-P3. The camera is also the first Cinema EOS model to feature brand new Canon Log2 technology, which enables the 15-stops of dynamic range, significantly wider than previous Cinema EOS cameras. The camera offers new versatility for sound recording too, supporting 4-channel audio recording in 16- or 24-bit and 48 kHz
DESIGNED FOR VERSATILITY
The EOS C300 Mark II boasts the iconic Cinema EOS design DNA – a modular body that can be adapted to suit the needs of each shooter and filming situation, through the extensive range of compatible accessories. Internally, the EOS C300 Mark II also includes built-in electronically controlled glass ND (neutral density) filters, which reduces the amount of light reaching the sensor by up to 10 stops in expansion mode. Compatibility with the RC-V100 remote control and optional Wi-Fi control also enables ease of use in a wider range of locations.
A new modular body allows users to connect the EOS C300 Mark II to a host of professional accessories.
The camera’s sensor read-out speed is now twice as fast as the original EOS C300, and further reduces rolling shutter distortion, allowing for crisp image capture in a moving environment, making it perfectly suited for capturing action sequences.Leveraging Canon’s rich heritage in lens design, the EOS C300 Mark II is compatible with more than 90 current EF and EF Cinema lenses allowing operators to use their existing EF mount lenses. In addition, the EOS C300 Mark II comes equipped with Canon Cine servo zoom lens support, delivering one of the most comprehensive selections of lens possibilities for movie and broadcast production available in the market today. For further flexibility, shooters can opt to change the lens mount from the default EF Mount, to EF Mount with Cinema Lock, or to the industry standard PL mount, as a service option.**
Firmware Version 1.0.1.1
- Adds [XC Protocol].
 - Adds [1.8x] to the Anamorphic De-squeeze setting.
 - Add 2048×1080/1920×1080 option to the 12G-SDI output when recording resolution is 4K or 5.9K RAW
 - Adds MON.OUT and HDMI Simultaneous output option. (1920×1080p/i)
 - Adds Look File function(3D LUT file .cube)
 - Adds ITU-R.BT.709 standard-compliant Gamma [BT.709 Standard / BT.709] the to the Custom Picture.
 - Adds Power Saving Mode. (by restricting some functions)
 - Adds [2x] option to the Magnification.
 - Adds [Mask 100%] to the [Aspect Marker]
 - Adds the ability to update the MON.OUT/HDMI output from 59.94P to 29.97P (or 23.98P) has been added.
 - Adds the option for 'same file name' simultaneous recording in XF-AVC or Cinema RAW Light.
 - Adds "B&W during Magn." as an option to the Assistance Function menu.
 - Modifies the default value of the assign button from "Magnification: Video terminal" to "Magnification."
 - Improvement in retaining recording settings when switching sensor modes
 - Clips can now be played by operating the joystick.
 - Adds Ukrainian language to the Language.
Price is dropping fast, $7499 now
https://www.bhphotovideo.com/c/product/1451214-REG/canon_0635c032_eos_c300_mark_ii.html
Price dropped to $8999
Rumors are that this camera will get 8K update. canon main goal is mostly announce it around NAB 2019. Dealers talk that most probably real 8K camera from canon will come inly in late 2019 or early 2020.
Firmware Version 1.1.1.1.00
- Retrieval of lens metadata, such as focal length, is now supported during XF-AVC recording.
 - Sensitivity adjustment has been added for the LM-V1 LCD Monitor.
 - Auto IRIS support has been added for the following lenses:
- EF-S 35mm f/2.8 Macro IS STM
 - EF 85mm f/1.4L IS USM
 - Fixed a phenomenon in which the CFast card recording and/or REC OUT terminal output footage may be momentarily distorted when the shooting frame rate is set to 120fps in the [Slow & Fast Motion (crop)] recording mode on cameras running Firmware Version 1.0.8.1.00 or later.
Canon Cinema EOS C300 Mark II Firmware v1.1.0.1.00
- Support for LCD monitor LM-V1 (separately sold) has been added.
 - Peripheral illumination/chromatic aberration correction has been added for the following lenses:
- EF-S 18-55mm f/4-5.6 IS STM
Canon Cinema EOS C300 Mark II Firmware Version 1.0.9.1.00
New firmware
Firmware Version 1.0.8.1.00 incorporates the following correction:
- Fixes a phenomenon in which a horizontal-line noise may appear for an instant in 4K RAW footage output from the REC OUT terminal and/or MON. terminal while simultaneously recording to a CFast card.
When a VPG130 CFast card is used simultaneously with a non VPG130 CFast card the camera may freeze. If the camera freezes, even if the live view image is displayed, all buttons and switches, including the POWER switch, will no longer respond, and the footage will not be recorded on the cards. (The time code and the recording indicator may continue to work.)
The camera can be released from the freeze condition by detaching it from the power supply (or removing the battery)
Workaround
If you experience this phenomenon please follow the steps below:
- Detach the camera from the power supply or remove the battery.
 - Remove both CFast cards from the card slots.
 - Use two of the same type of CFast cards: Either VPG130 or non VPG130.
 - Note: If there is only one CFast card inserted, you may continue use with no issues.
 Affected Products
EOS C300 Mark II/EOS C300 Mark II PL Digital Cinema Cameras (with Firmware V1.0.6.1.00).
We are planning to release updated firmware in mid-May 2017.
Review
Canon EOS C300 Mark II/EOS C300 Mark II PL firmware ver. 1.0.6.1.00 available
New firmware coming
Canon U.S.A., Inc., a leader in digital imaging solutions, today announced firmware updates for both the Canon EOS C300 and EOS C300 Mark II Digital Cinema Cameras being showcased at NAB Show New York 2016, November 9 and 10 at the Jacob K. Javits Center in New York City. These firmware updates support a number of feature updates for users including improvement of accessory support, ease of use, Dual Pixel CMOS AF (DAF) and creative flexibility.
The EOS C300 Mark II Digital Cinema Camera (EF-Mount) updates will allow various functions such as support for the Canon EVF-V70 OLED Electronic Viewfinder, WFT-E8 Wireless File Transmitter, Shutter Angle Priority, support for Zebra range at 65 percent or below, 2K Crop Audio Recording, Built-In Mic Audio off, and Peripheral Illumination Correction when using the new EF 24-105mm f/4L IS II USM lens.
The EOS C300 Mark II Digital Cinema Camera (PL-Mount) updates will allow various functions such as support for the Canon EVF-V70 OLED Electronic Viewfinder, WFT-E8 Wireless File Transmitter, Shutter Angle Priority, support for Zebra range at 65 percent or below, 2K Crop Audio Recording, and Built-In Mic Audio off.
Shot on C300 Mk II
Side-by-Side 4K Comparisons of Canon Log, Canon Log 2 and Canon Log 3
Recently was on a shoot with a C300 mk2. Be warned that its output options are weirdly limiting: https://www.facebook.com/DavidCMPeterson/photos/a.277946442237979.73677.260284580670832/1254780901221190/?type=3
Firmware Version 1.0.4.1.00:
Price is $11999 now
