Whoa, could this be the Leica buster?????? 19 lenses, 14 groups, there must be something going on.
Added lens photo.
It better be amazing cause the 25mm 1.8 is already great and cheap. For $1000 plus it has to be truly great.....it probably will be knowing Olympus though.
Wish they didn't do the Pro thing though and just make the best lenses they can at a price between this and the cheaper ones.
PR
Olympus expands its award-winning M.ZUIKO PRO lens lineup with the breakthrough M.ZUIKO Digital ED 25mm f1.2 PRO (50mm focal length in 35mm equivalent). This Micro Four Thirds® system lens boasts a superior optical design with 19 lens elements in 14 groups that thoroughly prevents aberration, distortion and fringing to achieve superb resolution and beautiful defocusing effects from its widest aperture setting of f1.2.
The fixed-focal length M.ZUIKO Digital ED 25mm f1.2 PRO minimizes chromatic aberration at the plane of focus and beyond, creating a stunningly smooth transition from the subject to defocused backgrounds. This design provides the perfect balance between high resolution and beautiful bokeh for a natural, three-dimensional appearance of the subject.
The M.ZUIKO Digital ED 25mm f1.2 PRO features a lightweight internal focusing mechanism that uses a single thin lens element for extremely fast and accurate focus point acquisition. The advanced MSC (Movie and Still Compatible) autofocus mechanism provides silent and smooth focusing and aperture performance, ideal for video capture. When combined with the powerful in-body 5-Axis Sync Image Stabilization of the Olympus OM-D and PEN cameras, the M.ZUIKO Digital ED 25mm f1.2 PRO provides outstanding resolution and blur-free images under almost all lighting conditions.
The M.ZUIKO Digital ED 25mm f1.2 PRO features dustproof, splashproof and freezeproof (down to 14°F/-10°C) construction, making it the go-to lens for professionals and photo enthusiasts looking to capture brilliant images in all types of shooting conditions.
U.S. Pricing and Availability
The M.ZUIKO Digital ED 25mm f1.2 PRO will be available in October 2016 for an estimated street price of $1,199.99 USD and $1,499.99 CAD. For a complete list of specifications, visit the Olympus website: getolympus.com
Excellent resolution performance from the widest f1.2 aperture
To ensure high-resolution performance from the center to the edges of the image, even at the widest aperture of f1.2, 19 lenses have been used in an effective layout to suppress all types of aberrations. Color bleeding (on-axis chromatic aberration) is suppressed by using a Super ED lens and two ED lenses. When combined with the color-canceling effects of an E-HR (special high refractive index) lens and HR (high refractive index) lens, peripheral color bleeding (magnification chromatic aberration) is effectively corrected.
Z Coating Nano lens coating technology maintains sharp, clear image quality. This advanced coating significantly reduces flare in backlit situations, optimizing shooting when strong light sources are present in the frame.
Beautiful defocusing effects
The lens design effectively eliminates chromatic aberration in focused areas as well as defocused areas to achieve a smooth transition from the subject to the background. When paired with the lens’s shallow depth of field and beautiful circular bokeh at the maximum aperture, images have a natural, three-dimensional appearance.
Fast and accurate focus point capture
The advanced optical design provides a single focusing lens element for fast and accurate focus point capture. The MSC mechanism enables high-speed, high-precision still image autofocusing and silent, smooth autofocusing for video. Even in shooting situations with a shallow depth of field, quick, accurate focusing allows for beautiful defocusing effects by accurately focusing on faces and eyes when users select Face Detect AF or Eye Detect AF on Olympus OM-D and PEN camera bodies. When combined with compatible OM-D and PEN cameras’ Silent Mode, users are able to photograph musical performances and piano recitals without making a sound.
Limits comatic aberration to depict points clearly and accurately
This lens is capable of depicting points of light accurately, a necessary feature when photographing stars with the f1.2 aperture setting. Aspherical and high-resolution lenses placed near the aperture effectively correct for comatic aberration. These elements enable both the brightness of f1.2 and a high level of optical performance, making it possible to capture points of light without distortion.
Other Features:
- This lens features dustproof and splashproof construction, with hermetic sealing in 11 locations. When combined with the dustproof, splashproof, freezeproof body of the Olympus OM-D series, users can take advantage of all types of shooting environments.
 - This lens boasts the same high-quality metal exterior design as the other lenses in the M.ZUIKO PRO series. It is equipped with the Manual Focus Clutch mechanism, which makes switching to manual focus possible by pulling the focusing ring toward you. A depth of field scale is included on the lens for pan focusing. And the L-Fn button on the lens barrel allows you to pause autofocus and assign other custom settings.
 - Close-up performance is supported by a minimum focusing distance of 30 cm (working distance of 19.5 cm) and a maximum shooting magnification of 0.11x (35mm equivalent: 0.22x).
https://www.ephotozine.com/article/olympus-m-zuiko-digital-25mm-f-1-2-pro-hands-on-29938
Homeless dog, still remember his poor and angry m43 owner
https://www.dpreview.com/samples/4774502912/pinnacle-prime-olympus-ed-25mm-f1-2-pro-samples-gallery
Homeless boy, just sold 25mm lens and body for food and pants
Added samples.
Statuette depicting m43 user asking gods to give him money for 25mm lens:
https://robinwong.blogspot.ru/2016/09/olympus-mzuiko-25mm-f12-pro-lens-review.html
This can be quite nutritious if you add them in bare water
http://www.mobile01.com/newsdetail/19693/olympus-m-zuiko-25mm-f1-2-pro
But this lens and you will never taste such things ever:
https://robinwong.blogspot.ru/2016/10/shutter-therapy-with-ming-thein-x.html?m=1
Kitty did not get food for almost a week after owner got 25mm lens
Meet happy owner! This guy bought Olympus lens on all last money!
Want to be happy like the guy above?
Go and quickly buy lens at https://www.bhphotovideo.com/c/product/1281433-REG/olympus_v311080bu000_m_zuiko_digital_ed_25mm.html
Cat in shelter, owner bough 25mm lens and thrown him out as had no money and time for him
https://m.flickr.com/#/photos/songmatin/sets/72157674880115885/
Look at the cats eyes - they literally ask you to go and buy old Minolta or Pentax lens instead.
So, if you don't care about roof or you cat you can already go and get one
At the risk of Vitaliy making fun of me for buying this overpriced lens...
Came in the mail yesterday, but haven't had a chance to get any real impressions yet due to dark, nasty weather. Can say this, though: Autofocus in photo mode (GH4) is one of the fastest and most accurate of any MFT lenses I've used. Autofocus in video mode is... well, pretty worthless. Hunts like crazy, sometimes never finding a subject, even in high contrast scenes. Standing a few meters from my dog, dog centered directly in frame, pressed and held focus button, watched the screen show a varyingly blurry dog for about 30 seconds before I just gave up.
I'll have a better idea of IQ in the next few days once my wife has a chance to have a go with it, then perhaps I'll have a Speedbooster Ultra and Sigma 18-35 for sale...
Well, it is just me adding some fun to boring stuff. Nothing wrong with owning this lens, well, may only this last cat - you need to feed it.
