Sorry about bad quality picture but there you have it, Series 9 filter attached to my old Minolta without mattebox. I drilled a circle to the filter holder with dremel, put 105mm-to-77mm filter step up ring to it and used also some tape. Better solution would be to use somekind of clamps to attach step up ring to filter holder but I haven't found proper ones.
The polarization filter turns in the filter holder.
From 77mm I use another step up ring to fit with different lenses.
The problem with this system is that it's hard to control in which way the filter holder will be when it is screwed to end. You cannot turn 3x3 filters when them are attached to the filter holder.
Question: Does it matter in which way 3x3 filters (e.g. white frost) are, or does them have to be always in 90 degree angle?
