Samyang 135mm F2.0 core specs
Samyang 135mm Cine lens T2.2
Samyang 135mm T2.2 Cine DS Ultra Multi Coated Lens for Sony E Mount Cameras, $299
@sam_rides_a_mtb just remember with manual lenses you need to enter the focal length in first
I don't expect any issues, just wouldn't mind seeing some samples before I make the purchase. Will probably just go to B&H and see if they have one to test. Adorama does not have a store sample.
Do you expect some issue with IBIS?
Anyone using this lens with a Metabones Speedbooster on a GH5 utilizing IBIS? Been looking at the DS EF-mount version for sometime to use with GH5 and GH4 w/ MB XL and occasionally on a C300 I/II.
Good deal, Rokinon 135mm F2.0 ED UMC Telephoto Lens for Pentax, $373
Can be adapted to almost all mounts.
Results from 36MP D800 sensor show an excellent performance of this lens right from f2.0 and all across the full-frame sensor. This is very impressive indeed! With such a sharp lens you can see signs of diffraction setting in ever so slightly at f8.0 and clearly at f11. Distortions are very low.
http://www.cameralabs.com/reviews/Samyang_Rokinon_135mm_f2_ED_UMC/
Image sharpness is excellent bordering on astounding. Even from f/2 the center is first-rate while the edges/corners are already very good. For a measure of this, I have seen samples from this lens alongside the (much more expensive) Canon 135L f/2, and the Samyang is better by more than a stop at the edges and more so at the corners. Stopping down from f/4 to (barely) f/5.6 allows for maximum sharpness over the whole frame. On m43 there is virtually no vigneting even at f/2.
http://www.eyesuncloudedphoto.com/blog/2015/10/26/samyang-135mm-f2-part-1
http://www.eyesuncloudedphoto.com/blog/2015/10/26/samyang-135mm-f2-part-2
The most surprising quality from this budget lens that had me falling over is its stunning clarity from accuracy in vibrant colors and tack sharpness.
http://www.adorama.com/alc/8206/article/rokinon-135mm-f20-manual-focus-lens-product-review
