Yuneec typhoon action cam, Osmo competitor
    The Typhoon ActionCam combines the impressive CGO3 camera gimbal with a handle for stable ground footage, allowing consumers to record videos and take photos like never before. When using the ActionCam, the camera stays level regardless of shaky hands or wobbling, making it the ideal tool for capturing life’s quick moments with unparalleled detail. The included CGO3 camera boasts impressive 4K resolution, four times higher than HD, 12 megapixel still images and slow motion 1080p/120fps video.
    Cam Specs:
    • Sensor 1/2.3″ CMOS Effective Pixels 12 Megapixels *Camera Lens 0.6 in (14 mm) /F2.8 FOV 115 Degrees
    • Electronic Shutter 1/30 – 1/8000
    • Working Temperature -10 Degrees C to 40 Degrees C
    • Dimensions 4.2 x 5.0 x 3.1 (in)
    • Weight 7.5 oz
    • Power Consumption 18 W
    • Video Transmission Range Upto 1640 ft
    SteadyGrip:
    • Dimension 9.06 x 2.76 x 7.48 (in)
    • Weight (without gimbal/battery) 12.35 oz
    • Angle Control Range (Pitch) 30-85
    • Power Pack 11.1V, 1400 mAh, 3C
    • Runtime 90 mins (depending on usage)
    here's some footage from the camera - you can see the action cam in some of the shots
    http://store.yuneec.com/as/q500-4k-parts/typhoon-actioncam.html
  • 1 Reply sorted by
