GH2 prest color grade
  • Excuse me a question, for my GH2 with Flowmotion V2 you look at my file attachment, and according to you is fine as I set? I mean then apply for mounting the color grade film style.
    Or do you recommend to change the presets? They told me with flow motion v2 should not then into the PC mounting apply the LUT cinemas because they are already applied flow of motion and then risvhia to ruin the colors, and all this true? thank you
  • 4 Replies sorted by
  • thank you
  • I do same as Brudney. Some use Standard instead of Smooth. (The last number is for noise reduction. Best to keep at -2, and if footage is noisy you can use software like Neat Video to do more effective noise removal.)
  • thank you
  • 99% of the time I use Smooth with -2 -2 0 -2
